2013 jaguar xf idle issue
Old Jul 16, 2019 | 06:08 AM
milan23's Avatar
Default 2013 jaguar xf idle issue
Hi, when I start my 2013 Jaguar xf supercharged 3.0 v6 (not always does it happen but 4 out of 10 times) the car will idle real high for a few seconds and then come back down to normal after a bit.
does anyone know why this is happening or how to fix this problem? thank you in advance.
Old Jul 16, 2019 | 06:21 AM
o1xjr's Avatar
Welcome to the forums.
Old Jul 16, 2019 | 07:28 AM
Welcome to the Forums.
I suggest a re-ask in the XF (X250) Tech Section.
My S Type V6, and the X Type V6, all start COLD at about 1400rpm, and settle to 950ish within 20 seconds, and down to normal after about 60 seconds. Maybe the same as the XF, not sure.
Good luck.
Old Jul 16, 2019 | 09:25 AM
Hello,
That's the Cold Start Circus playing up. My 2009 Hyundai does the same thing on all the but warmest mornings.
Old Jul 16, 2019 | 01:31 PM
milan23's Avatar
Default Jaguar
It doesn’t just start off high it goes like this
push button to start,
starts up regular and then it’s as if somebody stepped on the gas peddle with a real heavy foot shooting up super high
going going going then drops to normal like nothing happened
and its not all the time. It happens maybe 4 out of the 10 times I would start it. Always at a place where it’s embarrassing to start it as I just know it’s gonna happen
Old Jul 16, 2019 | 03:38 PM
Daf11e's Avatar
Welcome aboard.
Old Jul 17, 2019 | 02:55 AM
Welcome to the forums milan23,
Jaguars should start with high idle (say 1200 rpm) and then drop to normal idle after less than a minute depending on ambient temperature. This is to ensure rapid warm up and reduce emissions. If your XF is NOT behaving like this, I'd suspect a temperature sensor fault. A code reader is the best, fastest and lowest cost way to find out because throwing parts at a Jaguar soon becomes very expensive.
Follow this link https://www.jaguarforums.com/forum/xf-xfr-x250-44/ to the X250 forum for help, advice and information.
You can also uset the US Midwest Region forum by following this link https://www.jaguarforums.com/forum/us-midwest-39/ to find other members in your region.
Enjoy the forums.
Old Jul 17, 2019 | 05:23 AM
Welcome to Jaguar Forums milan23,
Old Jul 17, 2019 | 06:03 AM
welcome to the forum - enjoy!!!!
Old May 29, 2023 | 05:34 AM
chromaflare's Avatar
Hi mate, did you ever find the solution to the problem? I have the exact same model car with that exact same issue at cold startup. Nobody seems to know what is could be
Old May 30, 2023 | 05:20 PM
Welcome to the forums chromaflare,
The OP, milan23 has not been back on the forum since posting this question in July 2019 so you are unlikely to receive a reply.
Old May 12, 2024 | 08:56 PM
Jdabs's Avatar
I had this same issue on my 13 xf 3.0
by me it was a bad 02 sensor. Changed it and hasn’t happened since. (Engine light only came on once or twice but was happening for a long time with no engine light on)
Bader
Apr 7, 2019 09:42 AM
QuartzSTypeR
US Central
25
Jul 21, 2013 09:29 AM
Executive
Jun 26, 2013 10:22 AM
chacha
Jun 24, 2013 12:59 PM
