2004 fuel pump
Old Nov 6, 2015 | 06:17 PM
Toybreaker's Avatar
Default 2004 fuel pump
Has anyone ever replaced the factory pump with an aftermarket one?
I pulled the assembly out and applied 12 volts directly to the pump and it does not run.
I am not going to wait for 2 weeks while paying $350 plus shipping for a fuel pump to be delivered to Guam. There is a large JDM scene here so I am sure I can find a fuel pump of the appropriate size and fuel pressure flow to put into the stock assembly, however if someone else has done this already that would be great. I did a search and have not seen anything on this forum about it.
Just reaching out in hopes someone has done it so I can find out what pump was used....
Thanks. If I can't find anything by Monday, I will forge ahead and make it a DIY.
Old Nov 10, 2015 | 01:49 AM
Toybreaker's Avatar
turns out the fuel pump used in these cars are a standard FORD in tank pump
3m5u-9350-ab
I am buying a delphi version from NAPA in the morning and will follow on with photo's of the install....
$95 versus $300 sounds great to me!
Old Nov 10, 2015 | 04:33 PM
Toybreaker's Avatar
Crickets.... Damn.
Morning here in Guam, off to get the fuel pump.
I'll post the Napa part numbers and the photo's on the assembly once I get it all buttoned up.
I am pretty sure there are cheaper alternatives back in the states for this fuel pump but I have carquest and Napa. And neither one stocks a decent selection of parts.mthey order what they think they won't hold onto forever
Old Nov 10, 2015 | 04:50 PM
tbird6's Avatar
Just be sure it's the right pump.
You do know that the S type has two fuel pumps and they have different functions? Also if you have an STR it has a completely unique fuel pump set up unlike any other S Type.
They are also PWM driven so I hope the Ford pickup one is too. It's not like the old days where you put 12V on it and go.
There is also a module the drives the pumps. Are you getting power to the old pump?
Old Nov 11, 2015 | 08:45 PM
Toybreaker's Avatar
Yea it has power. The fuel pump is the standard in tank pump used by the E series vans, f series trucks, and several cars.
It fits and works just fine. I took pictures with my phone and tablet so once i get them in one place i will write up the DIY
Old Nov 11, 2015 | 08:56 PM
Cambo's Avatar
Somehow I missed this thread.
Please post up pictures and any other info you can share. Thanks!
Old Nov 12, 2015 | 02:51 AM
Toybreaker's Avatar
Certainly. It's nice to be the trailblazer for once instead of following others...
Old Nov 17, 2015 | 02:48 AM
Toybreaker's Avatar
Had some pm's asking about how it is working.
Starts right up,
However, I damaged the intake manifold gasket putting it back together.
So I just disassembled it again this afternoon, and dropped in a new victor reins set.
Cranked for about 8 seconds and fired up.
Now I get a p1000 and p1647
Time to replace that drivers side upstream O2 sensor!
Got a few things more important than uploading photos on my plate with work and moving back to the states in 6 weeks. I'll get the DIY done shortly
Old Nov 17, 2015 | 03:22 AM
JagV8's Avatar
That'll be a wideband, which sadly cost more than the older type.
Pablo picasso
Nov 18, 2015 10:27 PM
XJLFTW
Nov 10, 2015 12:41 PM
axr6
Nov 10, 2015 10:44 AM
Presence
Nov 3, 2015 08:47 PM
ttstanescu
Oct 31, 2015 09:58 AM
