AJ34S Piston Oil Squirters
Old Apr 1, 2014 | 08:51 PM
Tijoe's Avatar
Default AJ34S Piston Oil Squirters
I need to find a source for a couple of AJ34S Piston Oil Squirters.
I've searched the internet and as far as I can tell, they are nowhere to be found.
I am fairly confident that they have been installed in all AJ34 Supercharged engines between 2003 and 2009.
Anyone know of a source? Who makes them? P/N?
Thanks.
Joe
Attached Thumbnails AJ34S Piston Oil Squirters-img_0119.jpg   AJ34S Piston Oil Squirters-img_0118.jpg
Old Apr 2, 2014 | 12:02 PM
tbird6's Avatar
Hi Joe;
I have been looking for them for several years and Jaguar does not list them seperately except for the diesel. Those Diesel oil squirters look different so they won't work.
Have you tried used? Maybe someone with another blown up engine?
Old Apr 3, 2014 | 04:39 AM
JagV8's Avatar
In case you've not tried this, the techs sometimes find a part by figuring which other jags share the engine (or whichever subsystem) and trying the parts info for those cars. I suppose XKR, XJR.
Old Apr 3, 2014 | 09:05 AM
ccfulton's Avatar
The parts catalog does not seem to distinguish between supercharged and N/A for the oil system but if the nozzles are part of what they call the upper oil pan or sump assembly, then that might not be a *terrible* way to get them.
It seems that the whole assembly is in the 4-$500 range. Just a thought...
XK8/XJ8 4.2
AJ84055
XF/XK 4.2L
AJ810525
Old Apr 3, 2014 | 10:17 AM
avos's Avatar
Maybe these come close enough?
Set of 4 Oil Squirters Audi A6 A8 4 2 V8 Piston Squirting Jets Genuine OE | eBay
Old Apr 3, 2014 | 12:06 PM
Tijoe's Avatar
Originally Posted by avos
I saw those and contacted the seller. He states that there is no ball and spring inside them. he sent me the rough diameter of the outlet and it is significantly small than the Jaguar ones. I did purchase these today off of E-bay for a Mercedes CLK. They at least have the possibility of being adapted to work.
I believe that the squirters are considered part of the block. Perhaps one reason for a different P/N between NA and SC block? NA blocks don't have the drillings for the squirters, SC blocks are drilled and tapped and fitted with the squirters.
Old Apr 3, 2014 | 03:37 PM
Cambo's Avatar
I checked the Land Rover parts catalogue just in case they listed them separately, no luck...
Old May 26, 2014 | 05:37 PM
JagV8's Avatar
Quick update. They might be listed for the parts of the 4.2 SC in the XJ because they're in its Technical Guide (the one for 2004 MY - ref JJM18152140 - about p47 aka p57).
It calls them Piston cooling jets.
kthrash
Feb 25, 2019 10:20 AM
JCam
Oct 23, 2016 08:27 PM
ahunt4
Sep 25, 2015 03:43 AM
Tim Goz
Sep 17, 2015 09:11 AM
1964Daimler
Sep 9, 2015 11:28 AM
