Brake Flush:
Old Apr 28, 2014 | 01:09 PM
Wuzupez's Avatar
Default Brake Flush:
Hey guys, going to be doing a brake fluid flush and wondered if the STR's take dot3 or dot4 brake fluid?
Old Apr 28, 2014 | 01:44 PM
2000JagLvr's Avatar
Look on the reservoir cap. It should be listed there.
Old Apr 28, 2014 | 02:34 PM
Mikey's Avatar
The details are also in the owners manual and previous discussion here.
Old Apr 28, 2014 | 03:13 PM
caldoofy's Avatar
Dot 4 standard, dot 5 if full flushing.
Old Apr 28, 2014 | 03:27 PM
JagV8's Avatar
I'd stay away from DOT 5.
Looks like Jag spec is ESA-M6C25-A
ITT Super Dot 4 / Jaguar Super DOT 4
Old Apr 28, 2014 | 03:32 PM
tbird6's Avatar
Yea be a bit careful as you don't want DOT 5 because that's Silicone brake fluid and outside of collector cars that sit a lot it's not that great of a brake fluid. Very bad about entrained air which leaves you with a soft or squishy brake pedal.
Plus it's NOT compatible with the normal brake fluids so it's usually recommended to flush the entire brake system with Alcohol to remove all traces of the non-Silicone fluid.
We do have DOT 5.1 now which would be fine for a full flush.
Old Apr 28, 2014 | 04:03 PM
Mikey's Avatar
+1
DOT 5 is usually not recommended for cars equipped with ABS.
Old Apr 28, 2014 | 04:05 PM
JagV8's Avatar
Now that I didn't know!
Old Apr 28, 2014 | 04:46 PM
plums's Avatar
DOT 5 is not suitable for any production Jaguar in street or track use.
It is silicone based while all others are glycol based.
DOT5.1 is glycol based, but is a specialty fluid not used in any production Jaguar.
Old Apr 28, 2014 | 04:47 PM
plums's Avatar
The second part is bad advice and wrong. A little basic fact checking would avoid steering fellow members wrong.
Old Apr 28, 2014 | 05:32 PM
caldoofy's Avatar
5.1 is what's in mine after full flush, however thought it was a little more useful than the usual 'do a search' response I missed the .1 off but good to see the community stepping in with advice :-)
Old Apr 28, 2014 | 09:31 PM
Wuzupez's Avatar
Dot4 it is then! Thanks guys
PMKimpton
Aug 3, 2019 08:22 PM
flyrr100
Sep 29, 2015 03:47 PM
xjrjag
Sep 24, 2015 10:08 PM
wannajag
Sep 22, 2015 08:29 PM
Jefro
Sep 15, 2015 01:44 PM
