Comprehensive Fault Codes
Old Feb 14, 2019 | 10:03 AM
melhookv12's Avatar
Default Comprehensive Fault Codes
Does any one have a list or link to a comprehensive list of fault codes. Not just engine, looking for body codes as well. I have 3 B codes in trying to get rid of. Would like a more detailed explanation
Many thanks
Old Feb 14, 2019 | 10:13 AM
melhookv12's Avatar
Default Interesting Google and SDD info...
https://www.picoauto.com/support/topic17761.html
Old Feb 14, 2019 | 10:39 AM
JagV8's Avatar
They're included with JTIS which is fairly easy to download if you go looking. (E.g. On this site.)
Some are also on JagRepair.com - Jaguar Repair Information Resource
The "fix" for P1000 is to stop clearing the codes!! (Also don't disconnect the battery.) Then read up on drive cycle if it doesn't change to P1111 fairly soon.
Old Feb 14, 2019 | 12:31 PM
melhookv12's Avatar
Thanks JagV8. I did look on Jag repair. Couldn't find body codes
Will have a look at JTIS see if I can find them there.
Not fussed about P1000, or P1111 or if I see P1260.
Was a Jag tech many moons ago from 1992 upto about 2005. So seen those plenty of times.
Old Feb 14, 2019 | 01:21 PM
scottjh9's Avatar
I had b1265 and 2477....1265 was a bad servo motor at the door and 2477 was fixed with a module reflash....i i ended up doing a reconfigure as new module and it fixed the amp and d2b comm network fault
Old Feb 14, 2019 | 02:24 PM
melhookv12's Avatar
I had the pleasure of using JDS. Or Metal Mickey as we called him.
Any fault normally led to ' bulkhead harness
Old Feb 14, 2019 | 03:40 PM
scottjh9's Avatar
Luckily i haven't had to do any harness repair....but i will keep that tip in mind if i have any future Gremlins
Old Feb 15, 2019 | 05:07 AM
melhookv12's Avatar
Which module did you reflash. I have flashed the Audio unit and Voice module as new.
Old Feb 15, 2019 | 09:33 AM
scottjh9's Avatar
Those 2 and the amp and both electronic modules...i used sdd version 138.02
Old Feb 15, 2019 | 10:42 AM
melhookv12's Avatar
I couldn't find an option to flash the amp. I have installed it from another car, but the audio works fine .. As far as I know.
I have flashed FEM and REM also.
Might check fuse for the amp as it wasn't factory fitted, but I would imagine I'd get no sound if it wasn't working at all.
SimonRage
Sep 19, 2022 09:25 AM
Selsoft
Jun 18, 2013 03:18 AM
chinny4290
Jan 8, 2013 04:56 PM
chknhwk
Apr 8, 2012 04:30 PM
