Engine Management System - cost and availablity
Old Aug 26, 2009 | 03:23 PM
Delta66's Avatar
Default Engine Management System - cost and availablity
When I got my S-Type diesel the airbag warning light was showing, so under warranty the garage stated they would sort it. It went at first to an auto electrician, but I was told that he could not fix it. I was told that the engine management system had to go to Jaguar and they would refurbish it as no new ones are made anymore. I was also told that it was 'f'?%£g expensive'!
The problem is fixed, but out of curiosity, does anyone know how much the engine management system is to refurbish and are only refurbished ones available?
Old Aug 26, 2009 | 03:34 PM
JagV8's Avatar
I doubt they actually did what's been implied or said.
They almost never fail.
There are probably plenty of (used) spares but who knows? Contact some parts suppliers if you really want to know
(I'd worry about all the other stuff that fails quite often! Do some reading on here.)
Old Aug 26, 2009 | 04:05 PM
H20boy's Avatar
Delta, many airbag lights in the earlier s-types are either wiring harness related or the 'clock spring' behind the airbag. Did they blink at you before staying on?
You say the problem is fixed...may I inquire as to how?
Old Aug 26, 2009 | 04:09 PM
Delta66's Avatar
Yes the airbag light blinked and then stayed on. I was told that it had been fixed by sending the managment system to Jaguar to be refurbished.
Old Aug 26, 2009 | 04:22 PM
H20boy's Avatar
how many blinks...2? my initial guess is the clock spring, if you google it, you'll see what I mean
Old Aug 26, 2009 | 04:27 PM
Delta66's Avatar
No it was more like 7 or 8 blinks, I didnt count them, but definitely more than 2.
Old Aug 27, 2009 | 08:59 AM
H20boy's Avatar
hmmm, well I do know that a certain number of blinks is code, when (and if) it happens again, count them and make note. First set, then the second set of blinks. IIRC its a 2digit code (22 was mine, for example...two blinks, steady...two blinks, steady)
Old Aug 27, 2009 | 09:34 AM
Delta66's Avatar
Thanks. I'll bear that in mind should it start again. It was a steady 7 or 8 then the light stayed on. I have been asked to go back to the garage in a couple of months so they can check it, so I'll ask then.
toronadomike
Jan 22, 2026 10:13 PM
D.K
Dec 10, 2023 02:05 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
jdzubas
Oct 4, 2015 09:14 AM
TC Johnson
Sep 2, 2015 09:30 AM
