EPB Remove replace pre sale
Old Mar 1, 2014 | 01:37 PM
fergs03R's Avatar
Default EPB Remove replace pre sale
SO, after some joyus years with the STR Im going t move into something else.
the singular issue with the STR is a non working EPB. What I cant find is a guide to remove/replace the motor. I recall hearing it was above the back axle and hence a PITA
Anyone tackled this?? Im hoping to determine if I want to undertake or have it done by a shop prior to me putting it up for sale.
I mean I did the knock sensors and under SC pipe on my own which requires removing half the engine. But I don't have a lift if that's required for this task..
Thanks in advance
Old Mar 1, 2014 | 02:03 PM
Wuzupez's Avatar
Selling any of the performance upgrades off of it prior to sale?
Old Mar 1, 2014 | 02:26 PM
fergs03R's Avatar
selling as is.
Old Mar 2, 2014 | 09:34 AM
JagV8's Avatar
It's been posted here or else on the UK how to change the motor and I think more than once. I think it's also in JTIS - did you look?
Old Mar 2, 2014 | 10:33 AM
Mikey's Avatar
+1, and this is preceded by some basic troubleshooting to determine which component of the system is actually defective.
Old Mar 6, 2014 | 11:04 AM
fergs03R's Avatar
Yes Ive checked this site thoroughly.. I could have sworn I saw it abut a year back even with some pics of the internal gears, but after not coming across this time, I finally posted.
Yes, fully trouble shot , save from taking it to jaguar to diagnose
Old Mar 6, 2014 | 11:28 AM
tbird6's Avatar
If the electric motor needs replaced then yes it's above the rear diff. You need to remove a couple of bolts and drop the pumpkin down a bit to get at the EPB. Just make sure that's your problem and not the cables or the calipers.
See attached TSB's for more info.
This one is pretty good with pictures. No one has come up with the repair for the gears and the only option is remove and replace.
https://www.jaguarforums.com/forum/s...r-apart-53753/
https://www.jaguarforums.com/forum/s...storage-53003/
File Type: pdf
Old Mar 6, 2014 | 02:01 PM
Search for posts by phd12volt
Old Mar 6, 2014 | 03:49 PM
joycesjag's Avatar
Or click on the links right above Norris, posted by tbird.
Old Mar 23, 2014 | 12:41 AM
Wuzupez's Avatar
EPB? Electronic parking brake??? PITA.??
Robert1968
Jun 24, 2017 11:16 AM
CaneCounsel007
Dec 29, 2015 08:35 AM
RaceDiagnostics
Dec 11, 2015 10:12 AM
peterg19
Aug 30, 2015 08:48 AM
SD96XJ6L
Aug 29, 2015 03:20 PM
