Fuel Pump Removal S-Type
Old Jan 18, 2011 | 11:51 AM
mtfife's Avatar
Default Fuel Pump Removal S-Type
Lokked in the FAQ, but did not see it. Does anyone have suggestion on how to remove the big blue plastic flange securing the fuel pump to the tank. It appears that it should unscrew like a cap, but I can't seem to get enough leverage to make it budge. I am afraid I will break it if I force too much. Has anyone devised a tool of sorts to do this?
Thanks-
mtfife
Old Jan 18, 2011 | 12:28 PM
JagV8's Avatar
Maybe jag specify one? Try spxtools
Old Jan 18, 2011 | 01:04 PM
androulakis's Avatar
Thanks-
mtfife
Take a big flat blade screwdriver and a mallet or hammer. Put the screwdriver on the little raised ridges and start tapping, don't get too violent. It'll budge.
Take care,
George
Old Jan 18, 2011 | 02:16 PM
Riski's Avatar
Old Jan 18, 2011 | 03:27 PM
Great videos, but he's trying to remove the screw on flange holding the fuel pump into the fuel tank not the fuel filter
Take care,
George
Old Jan 18, 2011 | 09:21 PM
Riski's Avatar
I should read more
Old Mar 3, 2016 | 07:34 PM
Eribel Rosario's Avatar
What direction does the blue cap turn?
Old Mar 4, 2016 | 01:19 PM
clubairth1's Avatar
Community Influencer
The safest and easiest way it to make a home made tool.
Take a look;
https://www.jaguarforums.com/forum/s...-pumps-130587/
Old Mar 4, 2016 | 01:41 PM
NBCat's Avatar
If you're attempting to loosen the ring, it turns anticlock.
Old Dec 30, 2016 | 01:06 PM
Hscott's Avatar
Thanks-
mtfife
which direction does the ring turn. does it turntoward drive side
Old Dec 30, 2016 | 01:11 PM
Hscott's Avatar
Default Blue plastic cap
Thanks- which direction does the cap turn
mtfife
Old Dec 30, 2016 | 04:17 PM
abonano's Avatar
To loosen, tap counter clockwise. I mark the ring and body before loosening it. This way when you tap it to tighten (which you will have to) simply match up marks.
You should also change rubber gasket as a precaution. I used a block of wood/mallet. Homemade tool helpful. SPX tool = $200++
Flat blade screwdriver can break tabs.
Just my $0.02
Old Dec 30, 2016 | 07:23 PM
motorcarman's Avatar
RIGHTY-TIGHTY-LEFTY-LOOSEY
bob
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
Charlene n John
Sep 28, 2015 06:01 AM
deanh
Sep 6, 2015 08:20 PM
Sprayall
Sep 3, 2015 07:49 PM
