Fuel setup question
Old Dec 29, 2019 | 11:12 AM
James Finney's Avatar
Default Fuel setup question
2007 STR. There are 2 ports. The main question is should there be anything plugged into the driver side cap top?
Driver side. Should there be anything plugged in here ??
Passenger normal.
Old Dec 29, 2019 | 02:07 PM
Joedotcom's Avatar
Hi
My 2004 S-type R has 2 fuel pumps and 2 fuel gauges
1 pump and one fuel sender each side, under each cover
cheers
Joe
Old Dec 31, 2019 | 08:15 AM
Originally Posted by Joedotcom
Hi
cheers
Joe
the last picture, the one in wheel well. where is that located ? driver side front or rear?
Old Dec 31, 2019 | 08:16 AM
This one. i don’t have that. maybe the models are different later years
Old Dec 31, 2019 | 08:35 AM
JagV8's Avatar
It's just a drain, I think.
Old Dec 31, 2019 | 09:31 PM
Catfan01's Avatar
James..
This is chasing an issue or information?
We have a couple of pictures of the pumps under the seats..then appears to be the right rear fender well..
Old Jan 2, 2020 | 01:27 PM
Originally Posted by Catfan01
James..
What are you asking me. I don’t have either of those on my car no metal fuel return or pipe or the loose transparent fuel line. Which is why I (ask) so information ?
Old Jan 2, 2020 | 01:54 PM
JagV8's Avatar
There is no fuel return because (wait for it) it's a returnless system
By "loose transparent fuel line" do you mean the drain (post #5)? It's not a fuel line!
Old Jan 2, 2020 | 06:20 PM
Catfan01's Avatar
James-
I'm sorry if I confused you..after reading my post, I kind of confused myself.
Your first set of pictures was the fuel pumps under the seat. The second picture is what appears to be the fuel filler and a sunroof drain in the fender well.
I was asking if you are chasing a problem and need help?
Old Jan 6, 2020 | 09:47 AM
Aarcuda's Avatar
what year make and model is this? Looks like it has the TPMS sensor installed and my '06 STR doesnt have this.
EDIT I see its a 07 STR
Cambo
16
Jun 23, 2020 08:12 PM
SpinningWheels
Nov 11, 2019 04:54 AM
Mad Hatter
Sep 10, 2019 01:38 PM
winstonsalemncxk
Sep 19, 2017 03:17 PM
royeco
Feb 11, 2010 07:09 AM
