Gas door mech..
Old Apr 10, 2014 | 12:06 PM
Razorback31's Avatar
Default Gas door mech..
K I've seen several posts about the little pin that breaks off for the door.. Well looking at mine I see no such pin.. Here is a photo of the mechanism and the door.. It won't close but I do not see where a pin there would help?
Attached Thumbnails Gas door mech..-image-4019833622.jpg   Gas door mech..-image-830699311.jpg
Old Apr 10, 2014 | 12:53 PM
JagV8's Avatar
Looks like mine (well, sort of mirror image but then mine's RHD).
Old Apr 10, 2014 | 01:04 PM
Am I missing a part on the door? I do t see where it latches there is too much space between the lock and gas door
Old Apr 10, 2014 | 02:54 PM
JagV8's Avatar
I don't know - can't check till Sat.
Old Apr 10, 2014 | 05:08 PM
abonano's Avatar
You need to order part # XR818050 (Plastic part that slips onto the metal notch on the gas door) - the one with the "premium unleaded" label. (Yours looks to be totally missing) I keep a spare one handy as I had to replace it not too long ago...
Old Apr 10, 2014 | 09:14 PM
thank you, that is the part i need. i guess previous owner lost or broke it. is there a ford cross reference number so i can go to ford dealer? wasnt sure if the lincoln ls has something similar.
Old Apr 11, 2014 | 06:07 PM
ordered the part today from terrys jags, 2 day shipping and the part for a little under 11.00$ which imo is great.
Old Apr 11, 2014 | 09:18 PM
abonano's Avatar
When you get the part - put a bit of white lithium grease on the rails that will slide into the metal notch - take your time and the tang will lock the part in place to give it perfect alignment with the catch mechanism.
Just always close the gas door carefully moving forward.
Old Apr 12, 2014 | 07:13 AM
police666's Avatar
it looks like your also missing the screw on cap
Old Apr 12, 2014 | 11:36 AM
Richard Moss's Avatar
Aren't they all on the right hand side, regardless of RHD/LHD?
Old Apr 16, 2014 | 08:20 PM
phaelax's Avatar
Looks like I need the same piece. But looking at the pic (which looks just like mine) and a pic of the part from terrys jag, I don't see where the piece would fit. Anyone mind taking a pic of what a working door would look like?
Old Apr 16, 2014 | 11:05 PM
got it today, put it on, i have a closing door. it took 5 seconds to put on, not including the time it took me to flip it around because i put it on backwards...
Old Apr 17, 2014 | 12:31 PM
phaelax's Avatar
Upon closer inspection of this little plastic part, my blonde moment subsided and I realized it's for the door
I had already called the dealership earlier and the part was less than $6, but I don't need it anymore.
My problem was the latch wouldn't spring back after being released, as if the release cable in the trunk was stuck. After wrestling with the cable for 20min trying to get it to release the latch, I finally got it enough to wear the door stays closed and the electronic switch can still open it. There's probably a kink in that cable somewhere behind the panel that I can't reach, so no idea how I could replace it. But I can live without that cable.
Old Apr 17, 2014 | 04:22 PM
Six Rotors's Avatar
The manual release mechanism/cable gets fouled up with crap and corruption.
You can access it by removing the PS cover in the trunk---I was able clean and lubricate the mechanism without too much trouble.After clean and lube it was like new!
Old Apr 20, 2014 | 11:24 AM
Rickkk's Avatar
While we're on the same subject, does anyone know what fastener I should use to secure the strap for the gas cap back on for my 2005 Jaguar XJ8L? Thanks.
BillDJohnson
Dec 19, 2018 08:51 AM
06-XJR
Jun 30, 2016 04:33 PM
wesmc
Feb 9, 2015 05:54 PM
hawaiianjag
Nov 19, 2014 09:46 AM
vega1robert
Mar 3, 2014 02:06 PM
