Help dead battery
Old Apr 16, 2015 | 10:03 AM
Injekter's Avatar
Default Help dead battery
hi, i didnt put the battery on a trickle charger, ive not started it for a month,,, now the battery is dead, how do i open the trunk/boot? i know there is a post in the passenger wheel well but its a PITA,,, i mean thats really dumb to put it there...anyway,,, is there a way to open the trunk? thx
Old Apr 16, 2015 | 10:24 AM
JagV8's Avatar
Use key in lock.
You'll kick yourself when you finally notice the boot lock!! Under the J A G U A R, I think near the U.
Worth lubricating & using at least once a year, so it works when you need it.
Old Apr 16, 2015 | 11:15 AM
All is revealed here........
https://www.youtube.com/watch?v=IIpC5e8tbQU#t=37
Old Apr 16, 2015 | 12:34 PM
rayjag68's Avatar
OK if you can't open boot ,for any reason with the key ,if you have access to jump leads and spare battery or doner car then open bonnet connect pos lead to alternator, neg to earth on car press boot open button on fob that will give you access to boot and dead battery
Old Apr 16, 2015 | 02:24 PM
Injekter's Avatar
thank you.... im going to go home and find the key hole,, i seriously stared at the trunck lid ans saw nothing......: 0 if not that alternator idea is awesome
Old Apr 17, 2015 | 09:05 AM
pab's Avatar
pab
Also, there is an emergency battery jumping terminal under the lining of the passenger side front wheel just forward from the door.
But try the key, first... ;-)
Jaguar: Grace, Pace, and Space - Sir William Lyons
'08 Jaguar S-Type 4.2 "Satin Edition"
Old Apr 17, 2015 | 03:03 PM
tbird6's Avatar
Use extreme caution if you jump it off the alternator. There is a reason Jaguar put the post in the wheel well and not on the alternator. They are not cheap to replace.
Old Apr 17, 2015 | 04:02 PM
rayjag68's Avatar
Default boot open
no I should have been a little clearer you are not jump starting the car ,connecting only to get boot open .No engine should be running at all ,just power from doner battery to open boot ,..
Old Apr 19, 2015 | 08:23 AM
Injekter's Avatar
thx all, i did find the keyhole.... its up underneath to one side,, i guess one must remember that it doesnt look like a traditional key hole as the key is not a traditional shape. i just put up a new post... battery is charged all is running, but the check engine light is now on.....
Old Apr 19, 2015 | 05:27 PM
jkallinen's Avatar
That is because your battery was low and many components rely on it. You
will have to take to an Autozone or O`Reily and they can test it with a
code reader and clear those caused by low battery.
Bought my car a month ago and the battery was dead at the dealer, had
the same problem with check engine light when they got it recharged. New
battery to, they think someone looking at it left a light on.
Went and bought my own code reader after getting home.
Dagny
Jun 11, 2024 01:06 PM
99xk8guy
May 28, 2024 09:36 PM
Rivguy
Nov 13, 2022 02:55 AM
ferraripete
Sep 12, 2016 09:02 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
