A little help please. Sealing plugs from water
Old Dec 14, 2012 | 10:32 AM
darren-talbot's Avatar
Default A little help please. Sealing plugs from water
Ok all in a previous thread about the fault codes I was having cylinder 8 misfire and catalyst bank 1 below effiency. I took the jag to a specialist who opened her up to find 1. The plugs needed changing (96000 miles)
And 2. Water in two plug wells. He reccomended I deal the water out with Vaseline or something similar.
Just would like a little help understanding how to a actually do this job and if other members have had this water into the wells and how to prevent it. I remember reading a common problem is the water leaking in Down windshield?
Old Dec 14, 2012 | 11:43 AM
Brutal's Avatar
no there was a bulletin on this years ago. Just hylaseal/silicone the cover over the coils to keep out the water
Old Dec 14, 2012 | 12:04 PM
any chance you could go into a bt more detail foe me mate? im being stupid so want to fully understand what im doing 1st what cover should i silicone and what kind of silicone?
thanks
darren
Old Dec 14, 2012 | 12:13 PM
police666's Avatar
It's best to find where the water is entering the engine bay. A known problem is the seal at the bottom of the windscreen, allowing water to enter the engine bay and land directly on the back of the plug covers
Old Dec 14, 2012 | 12:33 PM
tbird6's Avatar
Well the best way is to test your car.
Run water down the windshield with the hood closed. Flood everything pretty good. Now let it drain a bit before opening the hood. Then look very carefully under the hood for any traces of water getting to the engine. Especially look at the TPS/Throttle body which is at the back of the motor in the center. Also check the cam covers.
The water usually gets thru where the wiper post come up thru the cowl. It’s dead center over the back center of the engine. Jaguar installs a round plastic shield under the post but sometimes it's not enough. This area needs to be sealed up with added silicone. Remove the plastic cowl cover before doing the repair.
I would retest after the repair to make sure.
Old Dec 14, 2012 | 01:14 PM
police666's Avatar
tbird6 has a good point, i also sealed that along with the bottom of my windscreen as water was entering at both points
Old Dec 14, 2012 | 06:25 PM
i have 5 0r 6 fixings missing from the scuttle panel below the windscreen im thinking water is leaking in here?
Old Dec 15, 2012 | 05:58 AM
joycesjag's Avatar
darren incase you haven't seen this thread:
https://www.jaguarforums.com/forum/s...ode-fix-61201/
Old Dec 15, 2012 | 06:47 AM
Thank you kind sir.
Old Dec 15, 2012 | 09:08 AM
Ok so thanks to joycejag for showing me that thread. I will at some point get round to doing this. But for the mean time I
1. Smeared a very generous amount of Vaseline to the rubber seal under the bonnet which sit on the windscreen scuttle panel.
2. Sprayed sg85 into the electrical plugs on the coil packs
3. Re connected the coil plugs and smeared Vaseline over them.
Hopefully the rain should not affect these coils or plugs again.
Old Dec 15, 2012 | 09:37 AM
joycesjag's Avatar
Thanks for the thanks, darren.
You really need to replace the missing "fixings" to keep the water out.
Old Dec 15, 2012 | 11:39 AM
clubairth1's Avatar
Community Influencer
As was posted elsewhere. DO NOT use Vaseline!! Use the proper dielectric grease which you can get at any parts store.
Old Dec 15, 2012 | 12:22 PM
JagV8's Avatar
Vaseline... why...
Old Dec 15, 2012 | 12:25 PM
Vaseline is fine to use. It's been used in battery connection s for years. Plus a jag specialist said its fine to use. It can not hurt anything.
Old Dec 15, 2012 | 12:30 PM
police666's Avatar
wont the heat from the engine just melt the Vaseline ?
Old Dec 15, 2012 | 01:09 PM
I'll let you know in a few days lol.
Old Dec 15, 2012 | 02:10 PM
police666's Avatar
i also used epoxy resin to seal the bottom of my windscreen, i just lifted the rubber seal a little bit at a time, applied the resin, and put it back in place, since then not a drop has got past it.
Old Dec 15, 2012 | 02:25 PM
JagV8's Avatar
It's not a battery connection, it's a coil. Just use the right stuff.
Old Dec 15, 2012 | 05:46 PM
Vasaline won't harm anything though?
aholbro1
Dec 29, 2024 06:46 PM
1100me
Jul 24, 2023 06:10 PM
mrplow58
Sep 9, 2015 11:27 AM
Saturbo
Sep 8, 2015 07:35 PM
d a
Sep 3, 2015 02:34 AM
