Rear ball joint boots
Old Aug 3, 2011 | 11:56 AM
Bodyman's Avatar
Default Rear ball joint boots
I noticed that the rear ball joint boots are split. Still grease in there and surely not worn out at 20 thou. Certainly not worth buying new control arms.
So I did a quick search and came up with this.
Ball Joint Boot - Auto Parts Warehouse
Perhaps an alternative if I could get the sizeing correct?
Old Aug 3, 2011 | 02:30 PM
gabrielduenas's Avatar
I've thought about purchasing these, just dont know how well they will fit.
Old Aug 3, 2011 | 06:41 PM
Bodyman's Avatar
The Energy Suspension site has them listed by dimensions. If someone had a set off to measure it would be great. I figure anything would be better that the split open ones.
This site has what seems to be all the dimensions available
http://www.suspension.com/bjb.htm
Old Aug 4, 2011 | 11:58 AM
Suspension Restoration Parts Co. - Polyurethane ball joint boots and tie-rod boots.
Thanks, I have a set of front uppers already taken off, I think the BJ's should be the same size as the rear.
I will measure them this weekend and order the approriate ones, I plan to take the vehicle to the shop and replace the rear tie rods and links. might as well do this at that time.
Old Aug 5, 2011 | 08:12 AM
Bodyman's Avatar
Please post back what you find. Part #s would be awesome. This would be a huge savings if it could work.
Old Aug 5, 2011 | 11:16 AM
Will do.
On a related note, this is the first time I see a seller offering the front upper control arm bushings. Along with the boots, this can save some of us $$ by avoiding having to purchase a brand new arm:
JAGUAR FRONT UPPER WISHBONE CONTROL ARM BUSH BUSHING | eBay
Does anyone know if the upper front control arm bushings and rear upper bushings are interchangable?
Old Aug 10, 2011 | 07:49 PM
Default Ball Joint Measurements
Ok, I was able to take the measurements, just had to clean up the front arm and take the boot off.
View from top:
Diameter Base of Ball Joint Measured 1 3/8":
There was a metal ring on this groove securing the boot. Diameter was 1.220 almost 1 1/4":
There is another metal ring securing the boot inside. Diameter was 5/8":
The diameter of this following piece was 1 1/16" :
Finally, the height from the base to the underside of the threads was 7/8"
Old Aug 10, 2011 | 08:04 PM
part 9.13101 seems to be the closest in dimensions. They are posted as 84-87 honda civic tie rod boots.
$4 a pair
Old Aug 10, 2011 | 08:27 PM
Bodyman's Avatar
Thanks for posting that. I assume you are going to give them a try. Let us know how they work out.
As a side note, looks like some over engineering on keeping the boot sealed and in place but they forgot to make it out of a material that holds up.
Old Aug 17, 2011 | 10:34 AM
I was able to find a universal dust boot at NAPA Auto with 5/8 shaft opening. It fits really well.
As for the rear upper bushings:
The diameter is not the same as the upper front arm bushings.
I will search for universal bushings that can be pressed in. Maybe another vehicles will fit.
Old Aug 19, 2011 | 08:10 AM
maxthrottle's Avatar
This could be a great fix for the cracked rubber ball joint boots that show up way too frequently. The ball joints are usually fine but a real expensive repair because of a $2 boot!. Please keep us posted what you find. I'm sure several of us are tuned in to your post.
Thanks,
Bob
dsnyder586
Dec 29, 2024 07:39 PM
H20boy
Dec 24, 2024 03:23 PM
1100me
Jul 24, 2023 06:10 PM
Richard_gib
Sep 12, 2015 07:08 PM
JagLove86
Sep 6, 2015 10:36 PM
