Sat Nav software reprogram file - for error 50 + 51 JTP 1072_1
Old Mar 20, 2011 | 03:49 AM
bikerjodie's Avatar
Default Sat Nav software reprogram file - for error 50 + 51 JTP 1072_1
Hi
SolidX had started this thread Blank Navigation screen
regarding his blank touch screen, a jaguar technician emailed some people the file that would reprogram the satnav (not the map dvd)
Would anyone have it that they could forward it on to me please as this is the only option i have left to try before trying to source another sat nav module?
I pressed the s/w button whilst in the diagnostic menu with no disc in theboot to update from, so i have a blank screen that will do nothing....
I have tried a new map disc in the sat nav unit and left the engin running for 1hr 10 mins last night but to no avail...
Any help in locating the .kwi file would be great...
I think Jaguar know the file as JTP 1072_1
Just for info, i can't get into the diagnostic menu now (holding down phone and menu)
If someone could tell me the other sequence of buttons to try to get into the screen, that would also be very helpful
regards
Popular Reply
Dec 13, 2013, 12:49 AM
vdubelu's Avatar
vdubelu
Smile The Fix for the Jaguar GPS Touchscreen 50 51 Error
Hello Everyone,
I recently purchased an updated Jaguar GPS DVD from eBay and after a few attempts at installing it, I also go the 50 51 error. I like many of you called everyone and searched online for countless hours looking for a quick and inexpensive fix.
I decided to look through the updated DVD disk and simply extract the LOADING.KWI file and burn it to a regular DVD-R disk and put it into the unit, what's the worst that could happen.
After being quoted almost $4300 from Jaguar to fix the unit, and another $2100 from a Jaguar specialist. I am extremely happy to report that a $.15 DVD-R fixed my issue.
I am attaching the LOADING.KWI file to this post in case anyone else has this issue.
Simply extract the LOADING.KWI file from the ZIP file and burn it onto a REGULAR BLANK DVD-R at the slowest your DVD will allow, mine was 4x. Make sure that you "FINALIZE" the DVD (at least in my program that's what it's called).
I turned the car on to eject the DVD that was in the unit and inserted the DVD that I just burned with only the LOADING.KWI file.
I then turned the car off and took the key out for about 30 seconds and turned the car back on and left it on.
I went to go make myself a cup of coffee while leaving the car on and when I came back outside, my GPS unit had come back to life and everything was working perfectly.
I then ejected the DVD with the LOADING.KWI file and inserted my Old Navigation DVD.
I'm sorry for the long post but wanted to make it as detailed as possible.
Again, this fixed my 50 51 error.
Hope it helps
Andy
File Type: zip
Old Mar 20, 2011 | 03:26 PM
JagV8's Avatar
If it's lost its firmware, I think you won't get in to the screens for that reason and I don't expect any other sequence will work. Sounds like you need the special disk, as you think. Maybe hosted somewhere?
Old Mar 20, 2011 | 04:09 PM
bikerjodie's Avatar
Trying to locate the disc is a task for indiana jones though!!
There's been a few people that have been given the software but it's relying on them to read this and then send it...
I'm gutted though, normally impatient anyway but this is making me tear the hair out of my head!!!
Old Mar 20, 2011 | 04:11 PM
bikerjodie's Avatar
the nav/temp up and audio buttons let me into the screen diagnostics but nothing else.... defo need the satnav firmware reprogram
Old Mar 21, 2011 | 05:41 AM
bikerjodie's Avatar
Got it from Jaguar...... navigation back to life
Old Mar 21, 2011 | 06:55 AM
joycesjag's Avatar
bikerjodie may be post up the link or where exactly you found the software for future members to find easily.
By "Got it from Jaguar" do you mean that your dealership was open on a sunday?
Thank you
Old Mar 21, 2011 | 11:25 AM
bikerjodie's Avatar
no
i'm in the UK so it was Monday and at the Jaguar Dealers
I had emailed a few people on here trying to locate it from Friday GMT
Old Mar 21, 2011 | 12:25 PM
joycesjag's Avatar
Ahhhh maybe in "location" you should state that.
thanks though
Old Nov 4, 2012 | 03:30 AM
colinthanhtran's Avatar
Hi I've been looking at your post I have exact same issue as yours I've bought the car screen not working I follow your steps . Hold nav button temp up and Audio my screen came back to life but I think it need a software update .can u you please me if you still got the file for update error code 50/51 can you email it to me colintran@optusnet.net.au thank you ..can you respond to my email address
Old Nov 4, 2012 | 04:00 AM
Cambo's Avatar
Welcome to the forum Colin, you should stop by our New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum and introduce yourself.
Nothing comes for free. But in this case you might be lucky.
Have a look here https://www.jaguarforums.com/forum/x...e3/#post524648
Old Nov 4, 2012 | 05:33 AM
ah ok will do im new to the forum just bought a jaguar last week ...i shall introduce myself thanks heaps
Old Jan 7, 2013 | 01:53 PM
wraxj8's Avatar
Default sat nav reprogramme file
Hi
I am a new member and I have the same problem , any guidance would be appreciated.
Old Jan 7, 2013 | 04:12 PM
JagV8's Avatar
All the answers are in the existing threads so just follow them.
Old Dec 13, 2013 | 12:49 AM
vdubelu's Avatar
Hello Everyone,
Hope it helps
Andy
File Type: zip
Old Dec 13, 2013 | 02:57 AM
Welcome to the forum vdubelu,
If I understand the sequence correctly, you:
1. purchased a pirate navigation DVD on eBay
2. this disc scrambled your Nav system
3. burned the loader from the eBay disc to a blank DVD
4. used the burned DVD to re-install the loader in your Nav system
5. put the original Nav disc back in the vehicle
If this is correct, you are back exactly where you started before buying the eBay disc?
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Dec 13, 2013 | 06:33 AM
JagV8's Avatar
The file could be useful for the next person who gets the blank screen out of the blue. (A small number have had that, and apparently not been trying dubious software.)
Old Dec 13, 2013 | 12:00 PM
vdubelu's Avatar
Hello GGG,
Yes you are correct, I'm back where I started although the firmware was upgraded with the new LOADING.KWI file. Although my navigation disk is still out of date, I'm happy to have everything back up and working again.
Andy
Old Dec 13, 2013 | 12:58 PM
Originally Posted by vdubelu
............. I'm happy to have everything back up and working again. Andy
I'll bet you are!
A valuable lesson not to use bootleg discs.
Old Dec 13, 2013 | 01:58 PM
tbird6's Avatar
Good Post Andy!
Thanks for attaching the file with instructions. It will help the next guy too.
Old Dec 13, 2013 | 02:00 PM
Aren't you tempted to try the update again now that you know you can fix it?
