2004 X-Type AWD Fuel Pump "spout" broken
Old Nov 10, 2019 | 07:01 PM
Comer Benbrook's Avatar
Talking 2004 X-Type AWD Fuel Pump "spout" broken
Hello fellow X-Typers.
Last week i went over a hump in a friends yard and broke the plastic tube coming from the top of the fuel pump casing that quick connects to the tube that leads to the tank side of the fuel filter. see picture.
does anyone have / or know where to just order the exterior casing? - my fuel pump itself work fine .
Thanks in advance
Comer..
Old Nov 11, 2019 | 12:41 AM
Dell Gailey's Avatar
That's not the exterior casing, that's the "pump" insert.
Old Nov 11, 2019 | 01:13 AM
Absolutely. But I believe it's a solid piece on the top under the plastic ring. I was wondering I it's possible to only purchase the top only ? Can't find that part only anywhere
Old Nov 11, 2019 | 04:50 PM
No
Old Nov 13, 2019 | 12:19 AM
JagQ's Avatar
Mine was cracked, a while back.
I took out the pump and welded it using a hot knife by melting the plastic and i used an extra piece of plastic to strengthen the joints.
It has been working since..... But in your case, since it is all broken, i do not know if that will work, you can try, if you have already cut an opening under the back seat for the pump, then it is worth a try, but if you are doing this by the book, then get a new pump.
i used Pattex Extreme.
to cover the welded area, stayed clear of the tip.
Best of luck.
Old Nov 17, 2019 | 06:21 PM
Default Update
I was finally able to get to the issue this weekend. the elbow was broken exactly at the elbow. I was able to sand down most of the pertruding edges of the lower part and placed a PCV elbow and some Permatek Motoseal ( petrol resistant) to seal. see below.
What do you think?
Old Nov 17, 2019 | 06:52 PM
timm525's Avatar
Interesting solution. I hope it works for you. I just replaced my fuel pump for about $55.00 on ebay. You posted part of this, the pic in your first post in that thread. It looks like you already have done the work around to get access, if that doesn't hold, replace the pump. Your mostly there.
Old Nov 17, 2019 | 08:37 PM
55 for the whole assembly? I'm sure it was used. Or did you only replace the round elongated pump itself?
Old Jan 1, 2020 | 07:56 PM
Update. . Our X-Type fuel pressure is pretty intense - more so, too much for the PVC elbow I initially tried as a quick fix
Old Jan 1, 2020 | 08:03 PM
And a mighty fine thanks to Dr.Dome for offering a second canister w. Pump at a more than fair offer and shipping was super fast...
So after oscillating sawing the opening and a few quick wha is with a punch n hammer the ring came off nicely..
Not the best tool to use...
the seal seemed to be in great shape sooo. I'm reusing it..
Old Jan 1, 2020 | 08:04 PM
Old Jan 1, 2020 | 08:28 PM
motorcarman's Avatar
I always wanted the fuel pump access from inside the car but Jaguar did not offer that option. (like the X200 and X350)
We always had to drop the tank assy.
If it was my car I would likely do it that way but customers don't always want the car cut and 'modified'.
Glad you found a solution.
Old Jan 1, 2020 | 10:19 PM
That's how I did it. Before and after pics =
worzella
Sep 2, 2019 10:19 AM
KrazyKGB
20
Aug 27, 2019 02:32 PM
Spikepaga
Apr 23, 2019 06:20 PM
Lagonia
Mark V - X 420G
Dec 18, 2016 07:55 PM
EZDriver
Aug 13, 2014 09:14 AM
