Anyone know where I can buy this?
Old Feb 18, 2018 | 01:52 PM
mrmarito's Avatar
Default Anyone know where I can buy this?
I need to replace these old gaskets/seals on my 2003 Jaguar X-type 2.5. My local auto parts store don't seem to carry them and I can find them online as well. There are two of them that go on both sids of the differential on this all wheel drive vehicle. Thanks
Attached Thumbnails Anyone know where I can buy this?-20180218_113659.jpg   Anyone know where I can buy this?-20180218_114504.jpg
Old Feb 18, 2018 | 03:38 PM
motorcarman's Avatar
TSBs are your friend.
XT308-01 has part numbers for you.
bob
File Type: pdf
Old Feb 18, 2018 | 03:43 PM
avern1's Avatar
I have attached a blow up from SNG Barratt's website. I assume you are looking for output seals. I am not sure they are supposed to look like that. Those maybe are severely damaged.
Old Feb 18, 2018 | 04:51 PM
Dell Gailey's Avatar
Wow, yeah pic of new looks very different from your old ones
Old Feb 18, 2018 | 06:12 PM
avern1's Avatar
Thanks for the tech bulletin motorcarman. It looks now like he needs the part called insulator in the SNG Barratt blow up. Good on you for recognizing the part in his glove.
Old Feb 18, 2018 | 07:40 PM
I also work on VWs and there is no gasket for the CV joints on most cars that use this type. Just a metal-to-metal joint is all that is required.
I have seen the gasket destroyed or missing and reassembled the propshaft without it.
The oil leaking thins the grease and that seems to be what 'creeps-out' without the gasket.
Sealant as per the TSB will keep the grease in.
bob
Old Feb 19, 2018 | 03:27 AM
Bob nailed the part numbers (c2s 22210) . After several hours (yup, I'm ****) trying to find a pic or info (seems to be a dealer only item and NO PICS ANYWHERE), I found this post from another member here (astromorg) on another site =
https://forums.jag-lovers.com/t/x-ty...cessary/219344
Here's a pic of a similar one (not Jaguar) =
Old Feb 20, 2018 | 03:05 PM
Robman25's Avatar
Have you checked for the equivalent item on the Ford Mondeo?
thefixer
Sep 11, 2011 10:21 AM
SirJag
Apr 19, 2011 04:35 AM
Darrenmb
Oct 31, 2010 05:21 PM
Jims XJ8
Feb 26, 2009 08:47 AM
