HELP Jaguar X-Type 2.5 v6
Old Oct 18, 2015 | 12:10 PM
aaron1579's Avatar
Default HELP Jaguar X-Type 2.5 v6
Hi guys im new to jaguar ive always wanted one ever since i was a young lad they are gorgeous cars ive now finally got one but it is riddle with faults and driving me crazy i dont no what to do with it now i have 8 codes coming up p0300. p0304.p0305.p1314.p1313.p0333. p1646 and p1000 i would be very great full if any one could give me any advice as to what is wrong with my jag as i just want her back to her former glory.
Old Oct 18, 2015 | 12:27 PM
Welcome to the forum aaron1579,
I've moved your question from UK & Eire Region to X-Type forum. this is the place to post tech questions about your X-Type and members here with the same model will be able to help.
Old Oct 18, 2015 | 12:30 PM
aaron1579's Avatar
Ok thank you .
Old Oct 18, 2015 | 02:30 PM
Thermo's Avatar
Veteran: Navy
aaron, from what you are descibing, you more than likely either have old spark plugs in the car and the need to be changed or you are getting some oil in the plug wells which is leading to a misfire. either way, getting the intake manifold off to look at things is going to be first on the list. because you are getting this far into the engine, i would advise that you plan on changing the plugs and also replacing the upper manifold gaskets. as you pull the plugs, you should get a good idea of what is happening.
must you replace the upper manifold gaskets? no. but, as these cars get older, this is being done to prevent future issues relating to vacuum leaks. besides, the gaskets are cheap and pulling the intake off takes a little bit of time and if you are in that far, might as well get it all aet up for the long haul.
if you need some help getting the intake off, let us know. there are a few write ups on how to remove the intake. lan about three hours to pull the intake, replace plugs, and then get it all back together. after you do it the first time, the follow on times will be in the two hour range.
Old Oct 18, 2015 | 03:33 PM
aaron1579's Avatar
Thermo thanks so much for your advice i had the intake manifold off to check plugs they look really old and 2 of the front 3 plugs where covered in oil ive cleaned them up put them back in rebuilt every thing back up cleared faults started car took it a drive now just has 3 faults which are p1647 p0333 and p1000 . I think i will use your advice and replace plugs and upper manifold gaskets see uf that makes a difference .
Old Oct 18, 2015 | 04:41 PM
aaron1579's Avatar
Do the intake manifold gaskets need a sealer or do they get fitted dry?
Old Oct 18, 2015 | 04:48 PM
Lubrication's Avatar
Dry fit. Clean the mating surfaces. I used acetone on the metal surfaces and a lint-less cloth with a little warm distilled water on the non-metal surfaces.
Old Oct 18, 2015 | 05:18 PM
aaron1579's Avatar
Thanks lubrication
Old Oct 18, 2015 | 05:22 PM
aaron1579's Avatar
Where is the best place to get the intake manifold upper gaskets from and what are the best spark plugs to use ive been told to use double platinum ?
Old Oct 18, 2015 | 07:08 PM
dwclapp's Avatar
Old Oct 19, 2015 | 12:15 AM
Corycarlo's Avatar
I had an error code for a bad coil causing misfire. I pulled the intake and while it was off I made sure to do the spark plugs and change the one bad coil. Not a hard job, just take your time and don't drop anything into the motor. Now I did have a moment that frustrated me after the job was done. Within the week I had a new code, it was for the knock sensor.... That's under the intake. It's up to you but they do go bad and if you have the intake off I would do that too as the sensor is a cheap part.
Old Oct 19, 2015 | 01:15 AM
JagV8's Avatar
P0333 is knock sensor fault.
P1647 is O2 sensor fault.
Worth the workshop manual free download
Old Oct 21, 2015 | 02:50 PM
aaron1579's Avatar
Hi guys i have a problem i have replaced the all 6 spark plugs and both top and bottom lamda sensors and my car still isnt running right engine management light is still flashing im still getting codes 1647 and 0333 and some times i get 6 other codes 1314 1313 0304 0303 0305 0302ive also noticed that when i drove car then parked it up to check it my catalytic convertor was glowing red could this be the problem? I am coming close to getting rid of her .
Old Oct 21, 2015 | 11:38 PM
dwclapp's Avatar
aaron: I fear the catalytic converter may be damaged. Hopefully someone has a more optimistic outlook. The indicators are: (1) a glowing red converter, and (2) a flashing CEL warning of exhaust conditions that can or already have damaged the converter.
Some folks revive damaged converters. Others replace them. Here's a few threads on both options. Again, I hope other's respond with a better prognosis.
https://www.jaguarforums.com/forum/x...nverter-64693/
https://www.jaguarforums.com/forum/x...placing-33007/
https://www.jaguarforums.com/forum/x...estions-90385/
https://www.jaguarforums.com/forum/x...and-r-i-66236/
https://www.jaguarforums.com/forum/x...24/#post451742
Old Oct 22, 2015 | 02:12 AM
JagV8's Avatar
Flashing MIL = misfires then and there so bad they're causing cat damage
Bad coils or some such but you need to find & fix the misfire cause ASAP.
caldoofy
Sep 28, 2015 08:43 PM
Amberlinder541
Sep 26, 2015 01:10 PM
Larry-Cleveland
Sep 25, 2015 08:42 AM
Joshua
Sep 24, 2015 07:37 AM
