leaking trans--harness?
Old Nov 16, 2013 | 06:15 PM
mhamilton's Avatar
Default leaking trans--harness?
My trans has developed a slow drip, occasionally leaves a drop on the garage floor. From what I can tell it's leaking from the little 2-wire box/harness that's on the right rear corner (behind the fill plug). Is this the infamous leaking harness?
What part do I need to get to replace this?
Figure it will be time for a fluid and filter change (67k miles) so timing is good for this problem (if there could be such a thing). I've bookmarked some other threads on the trans fluid change. Am I correct that some folks have used Valvoline or some other brand synthetic ATF with no issues on this ZF box?
Thanks,
-Michael
Old Nov 16, 2013 | 07:11 PM
motorcarman's Avatar
The connector is a common source of the leak and I replace them often.
http://www.thectsc.com/images/pdf/th...eplacement.pdf
I use ZF Lifeguard 6 Transmission Fluid but people use whatever they want.
If after contaminating the system with different fluid you experience the 'bark/squeak' or other shift anomalies, you will know what caused it.
On the other hand, you will save maybe a hundred dollars using alternate fluids.
All sorts of opinions but that is what makes a forum.
bob gauff
Old Nov 17, 2013 | 11:05 AM
mhamilton's Avatar
Thank you! That's very helpful info.
I'll have to look again, that 15 pin round connector is not what I saw on the back of my trans. What I was looking at was 2 wires and a square connector. But definitely on the rear right of the trans, in the spot that round connector is supposed to be. Or maybe I need to look up higher. Is there a smaller harness under the big round one?
So the sleeve is what I need to replace, the rest of the valve body/harness connector is kept?
I'll probably stay with the OE fluid just because I don't want to do this job again.
Old Nov 17, 2013 | 01:24 PM
clubairth1's Avatar
Community Influencer
It's very tight in that area and even on a lift it's hard to see.
Old Nov 18, 2013 | 07:12 AM
mhamilton's Avatar
Yep, that's it! So can that sleeve be replaced with the trans in the car?
Old Nov 19, 2013 | 04:44 AM
clubairth1's Avatar
Yes but only with the pan removed. So do it with the fluid/pan change.
As Bob's pictures show there is a white plastic tab on the valve body (Mechatronic is what ZF calls it). This allow the sleeve to be pulled out from the outside once the wire harness is unscrewed. I have found just unscrewing the harness is pretty hard too and it's plastic.
Old Nov 19, 2013 | 08:12 AM
mhamilton's Avatar
Ah, I see now. I missed that when I looked over the PDF in Bob's reply. Well, I'll add all of that to my to-do list. Thank you all for the help!
Old Nov 19, 2013 | 09:07 AM
cjd's Avatar
cjd
The sleeve comes with the outside o-ring that seals the sleeve to the housing. There is also an inside o-ring that seals the wire bundle to the sleeve. You must purchase that one separately.
Old Nov 20, 2013 | 08:50 AM
clubairth1's Avatar
That's a good point and the outside one can be reused as it is not known for leaking.
Pristine97XK8Convertible
Mar 5, 2025 10:32 AM
Poet
Oct 2, 2015 09:00 AM
ahunt4
Sep 25, 2015 03:43 AM
arskemp
Sep 21, 2015 02:19 PM
Tim Goz
Sep 17, 2015 09:11 AM
