Priority Warning
Old Aug 4, 2018 | 08:16 AM
Yoosey's Avatar
Question Priority Warning
X350 3.5 V - 51,000miles
The above Red lamp on speedo is showing intermittently. Any ideas?
Kevan
Old Aug 4, 2018 | 09:47 AM
Partick the Cat's Avatar
Anything showing in the message centre in the speedometer when the light comes on ?
Old Aug 4, 2018 | 10:56 AM
Yoosey's Avatar
Thanks for your speedy reply. My car is a Japanese Import and has not been converted to English (if indeed it can be). Is this possible and, if so, do you know how?
Regards.
Old Aug 4, 2018 | 11:03 AM
JagV8's Avatar
Try an expert. Probably a jag indy.
They can check the fault, too.
I'm struggling with the concept of having such an import that has NOT already been made suitable i.e. put into English etc!!
Can you take a picture?
Old Aug 4, 2018 | 11:05 AM
JagV8's Avatar
BTW it must be possible that the car is not legal on UK / EU (public) roads...
Old Aug 4, 2018 | 11:06 AM
Yoosey's Avatar
Jag Indy is the plan but he is very busy for a couple of weeks, so just wondered. Re: not all converted to English - it was the price and low mileage 51k. Hope I didn't get a lemon.
Old Aug 4, 2018 | 02:31 PM
ChrisMills's Avatar
Sure the car is legal. Here's the UK rules (which seem similar to NZ):
https://www.gov.uk/importing-vehicle...al-recognition
Besides, in the PC-Correct UK it might be considered (Ethnist?) to ban a language.
I have 3 Jap imports (in NZ) and the Jap indigenous cars (Hondas) can't be changed.
Playing with my X358, the Display language setting only affects the main display not the odometer screen. (My odometer is English).
Another thing, (radio frequencies), I don't have a Region setting in the Audio Setup (as Partick doesn't), yet my frequencies are not Jap ones.
I suspect the Jag specialist my dealer used, must have replaced the entire relevant software. Though X358 could be different.
And as an aside, I suspect Japan doesn't salt it's roads. Be proud of your Jap import !
Yoosey, would you mind sticking your car model in your signature?
Old Aug 5, 2018 | 05:37 AM
Yoosey's Avatar
I have this Warning - Please - does anyone know what it is or able to convert to English?
Priority Warning
Old Aug 5, 2018 | 06:09 AM
Yoosey's Avatar
I am seeing this warning.on my Japanese Import which is not yet converted to English
1. Does anyone know what it means or can translate?
2. Is there an easy way to change language to English, I managed it easily enough on the Radio although one could never have guesed which buttons to press.
The car drives ok but the Nearside Front suspension definately need looking at.
Priority Warning
Old Aug 5, 2018 | 08:08 AM
motorcarman's Avatar
A quick search yielded this...........................................
https://www.jaguarforums.com/forum/x...isplay-190553/
Either a forum or internet search.
bob
Old Aug 5, 2018 | 08:43 AM
Try this:
Display language
To change the display language, switch the ignition ON while pressing the ML/km switch. The trip computer will display the current language. Press the ML/km switch repeatedly to cycle through the available languages. Once the correct language is selected, press the A/B switch. The new language will be selected after a delay of three seconds.
Old Aug 5, 2018 | 09:01 AM
Yoosey's Avatar
Thanks v. much. I got the following from an old post and it worked a treat:
1. push m/km button
2. stay on that button & turn ignition switch to position 2
release button and push again
3. when language change appear press A/B and scroll through until you come to English.
Worked a treat and and my Priority Warning was fixed by 0.5ltr of coolant and there was me panicking.
Old Aug 5, 2018 | 09:20 AM
JagV8's Avatar
Well that looks painful. Has it even been followed for the car?
What now? Where's that come from???
Old Aug 6, 2018 | 04:11 AM
ChrisMills's Avatar
Smile
Ha! I spent a while with Japanese alphabet, just for fun and that lead nowhere.
Then I compared my Jap manual with the English one (Jap P4-12 = Eng P94!) and determined Engine Coolant.
Then I saw the Language selection.
By that time, you guys were WAY ahead of me! Cheers and glad it's sorted.
Old Aug 6, 2018 | 04:33 AM
Yoosey's Avatar
I Googled it and was taken to an Old Post by Forum Member
Old Aug 6, 2018 | 05:50 AM
Fraser Mitchell's Avatar
1. push m/km button
Except why did it need 1/2 litre of coolant ! If it were me I'd be looking around the engine bay.
Old Aug 6, 2018 | 06:03 AM
Yoosey's Avatar
Having it in to Indy Jaguar outfit for general once-over.
Old Sep 7, 2018 | 09:58 AM
Yoosey's Avatar
Coolant Leak turned out to be Leak on "water tower" pipe outlet on coolant system below inlet manifold.
f_in_seattle
May 3, 2022 04:18 AM
nasa25
Oct 13, 2015 07:11 PM
slmskrs
Nov 12, 2013 02:08 AM
henry k
Oct 12, 2012 05:54 PM
JLee
Oct 6, 2012 09:46 AM
