Battery Question
Old Sep 28, 2019 | 08:37 AM
Wayne Lea's Avatar
Default Battery Question
My battery died on my 1997 XJ6 VDP.
Since there are computers and all sorts in the car, is replacing the battery as simple as loosening the terminals and replacing the battery OR is there a procedure to replacing it.? I am concerned that if I change the battery I will get lights on at the dash....because I did not take a fuse out prior to removing the battery or something of that nature.
Thank You.
Wayne.
Old Sep 28, 2019 | 10:13 AM
motorcarman's Avatar
Your car is known as X300.
This section is for the X350.
You should post in the correct section for a more specific response.
Old Sep 28, 2019 | 07:56 PM
Wayne Lea's Avatar
Cheers mate.
Old Sep 28, 2019 | 07:57 PM
Wayne Lea's Avatar
Default Battery Question..
Thank You.
Wayne.
Old Sep 28, 2019 | 09:44 PM
Don B's Avatar
Hi Wayne,
I have disconnected batteries in numerous X300s with no problem after reconnection. I seem to recall that in some regions of the world the radios required a security code after battery disconnection, but I don't believe this is the case in the U.S. Just to be certain, check your Drivers Handbook/Owners Manual.
Cheers,
Don
Old Oct 1, 2019 | 09:26 PM
Granite6's Avatar
Default should be good
I have a 1996 VDP U.S. spec (X300) and have replaced the battery without issue, so don't worry about the "memory retainer".
Note- I do have an aftermarket stereo, so that may be one difference to investigate.
Old Oct 1, 2019 | 09:39 PM
Don B's Avatar
Hi Granite6,
Welcome to the Jaguar Forums! It's great to have you with us! I see that you have already posted an introduction and we're glad to hear your contribution to this thread.
Cheers,
Don
Old Oct 1, 2019 | 10:59 PM
Granite6's Avatar
Thank you Don,
I've been lurking on this site for some time. Seems I need to give something back to the cause.
Old Oct 2, 2019 | 07:29 AM
Wayne Lea's Avatar
Cheers:
I went ahard and changed the battery without any issue.
Appreciate the post mate.
Wayne.
cat_as_trophy
Nov 29, 2025 11:08 AM
snkpkp
Jan 14, 2021 09:52 AM
BigCat09
Dec 4, 2019 03:06 PM
Mark Scotton
24
Jan 23, 2013 09:27 PM
