DISCONNECTING BATTERY
Old Apr 14, 2008 | 06:32 AM
ey_shyguy's Avatar
Default DISCONNECTING BATTERY
hello, i read that when disconnecting the battery, the purpose is to let the throttle plate readjust itself to proper idle. I did mine because it began running weird, and engine light came on. Since doing so, two days ago, car is running weird with rough idle and hesitations at lower rpms. How long can it take to re-learn?
Old Apr 14, 2008 | 11:38 AM
ey_shyguy's Avatar
Default RE: DISCONNECTING BATTERY
there is no engine light. should i get an obdII scanner? will any codes show up?
Old Apr 14, 2008 | 06:18 PM
jag_genius's Avatar
yeah there shud be if it set one before.. may have a misfire.. or throttle problem or tensioners failling.
Old Apr 14, 2008 | 07:50 PM
ey_shyguy's Avatar
i did put on a sc pulley from jaguarxp.com could this cause a physical problem?
Old Apr 14, 2008 | 09:21 PM
FactoryJaguarTech's Avatar
Yes that cause a problem. Try swapping pulley back and see if cleared.
Get it scanned anyway first just to be sure.
Old Apr 14, 2008 | 09:37 PM
ey_shyguy's Avatar
LOL, I MECHANIC HAD TO CUT PULLEY OFF... HE SCANNED IT WITH NOW ENGINE LIGHT AND NO CODES CAME UP. I ALSO PUT IN A NEW ACCEL COOL BLUE AIR FILTER. ARE THESE JUNK? AFTER I DID THESE THINGS MY LOW RPM HESITATIONS STARTED, AND ONCE IN A WHIL ASC AND ENGINE FAILURE LIGHTS COME ON EVERY NOW AND THEN. I HAVE ONLY DRIVEN 60KM SINCE DISCONNECTING BATTERY. ARE EGR PROBLEMS COMMON ON XJR'S
THANX
Old Apr 14, 2008 | 10:05 PM
The_Ikon's Avatar
I have the JagXP air intake on my XJ8L for about 4 years or so and have been veryhappy with it and the sound/performance... I can not comment about the pulley in which I plan to get one for my STypeR. I hear the pulley is a great performance mod
Old Apr 15, 2008 | 06:40 PM
ey_shyguy's Avatar
my engine light isn't coming back on so i can scan the car...
this sucks. car is still running the same . should i hook a scope to it? maybe start checking plugs/coils?
Old Apr 15, 2008 | 07:22 PM
IF NO CODES STORING, could be throttle body.
Old Apr 15, 2008 | 07:25 PM
If you.can find a good dealer, they can do athrottle download.
Old Apr 15, 2008 | 08:38 PM
ey_shyguy's Avatar
do you mean they can load info?
Old Apr 15, 2008 | 08:47 PM
No....they can interrogate the throttle to see if it failed without storing code. Some dealers I am sure wont know how. It is a very important resource for helping to diagnose this kind of failure. If your XJ is a 98, there was a recall for the throttle body.
PM me the last six of your VIN.
Old Apr 15, 2008 | 09:54 PM
ey_shyguy's Avatar
vin: 830741
thanks so much FJT!!!
Old Apr 16, 2008 | 02:07 PM
ey_shyguy's Avatar
GOT CODE TODAY
1612 - THROTTLE MOTOR MALFUNCTION
CAN ANYTHING BE DONE, OR CAN I GET A THROTTLE BODY FROM SOMEWHERE ELSE THATS RELIABLE?
DEALER WANTS OVER $2000
Malihide
Apr 2, 2016 04:05 PM
puddled
Sep 24, 2015 01:09 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
DuhCar
Sep 11, 2015 10:58 AM
