Driver side rear door won't unlock
Old Aug 29, 2016 | 12:18 PM
Jim Goodall's Avatar
Default Driver side rear door won't unlock
Hi folks,
I have a 2002 Jaguar XJ8 - 4.0
I have a problem with the drivers side rear door - it won't unlock
The silver lock button on the door does not raise when the central locking button is pressed on the key fob. I cannot open the door by operating the interior door handle either.
Any ideas on how I can resolve this?
Many thanks!
Jim
Old Aug 29, 2016 | 02:06 PM
Welcome to the forum Jim,
I've moved your question from General Tech Help to X308 forum. Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Aug 29, 2016 | 02:25 PM
avern1's Avatar
Does the door unlock and open with the key and outside handle? If it does then you have most likely broken the cable that runs from the interior door handle to the lock mechanism.
You can do a search in the X308 section for door cable. There are plenty of step by step instructions for changing it. Its about $80.00 from Jagbits.
Old Aug 29, 2016 | 02:31 PM
Hi Vern, thanks for the suggestion, but no - the door stays locked whatever, I can't open it at all.
Old Aug 29, 2016 | 06:39 PM
motorcarman's Avatar
Roll the window down and PULL UP on the knob (hard). Maybe while operating the 'UNLOCK' keyfob button or have some work the locks from the driver's door.
Remove the door trim panel and lube all the latch linkage.
You will have to get aggressive with it.
bob
Old Aug 30, 2016 | 11:19 AM
So I have managed to pull the lock button up by pulling the interior door handle, which raises the silver button just proud of the collar, however the door remains steadfastly locked!
When I let go of the interior handle, the button returns to the locked position as if it were sprung.
Any other suggestions?
Think I'm gonna have to take it to my local Jag specialist.
Old Sep 10, 2016 | 10:01 AM
Pamos's Avatar
Hey Jim,
Were you able to get this resolved? I have the same exact issue with my 2003 S-type for a week now, except my FOB also quit working AGAIN about a month ago.
Old Sep 10, 2016 | 03:37 PM
Originally Posted by Pamos
Hey Jim,
So I took it in to my local garage, they stripped it down and opened it for me.
The solenoid that drives the door lock has given up the ghost on mine and needs replacing.
Hope this helps
Old Apr 26, 2020 | 11:35 PM
Jacki747's Avatar
Default X Type 03 Drivers door locked and will not unlock
Hi Jim Goodal
Any idea how the garage were able to strip inside the door with the door locked.
Old Apr 27, 2020 | 12:30 AM
Jacki747's Avatar
Hi Bob I have the same problem but it's the drivers door and it won't open with the key or from the inside, any suggestion on what I can do please would be appreciated. X Type 03
Old Apr 27, 2020 | 07:48 AM
A.J.P's Avatar
Hi Jacki747, I see you have the X-Type Model.
You might get a better response to your question in the X-Type section of the Forum,here's the link:
https://www.jaguarforums.com/forum/x-type-x400-14/
Also if you add the year,model,milage and engine size in your signature.
This will benefit you over & over again when asking for help as it immediately shows any member what model / year you are asking about.
Hope you get it resolved and good luck.
Take care.
Andy
Old Nov 2, 2020 | 08:24 AM
montypeek's Avatar
Default Drivers door locked
Jim, I have a 2002 XJ8 With the exact same problem. I cannot figure out how to get the door panel removed from inside the vehicle. Any advice from the forum would be greatly appreciated.
‘Monty Peek
AJS57
Mar 27, 2016 10:31 AM
Nov 26, 2006 04:34 PM
Nov 2, 2006 04:22 PM
Oct 4, 2006 12:42 AM
Jun 28, 2006 03:53 AM
