High level brake light
Old Jul 12, 2013 | 04:41 AM
Jaygee's Avatar
Default High level brake light
Hi. Can anyone tell me how the high level brake light assembly fastenes in position?
I have a 2000 XJ8 and the brake light is loose and wedged against the rear window with an air freshener underneath it otherwise it just flops about on rear parcel shelf i would like to fix it properly if possible...
All suggestions gratefully accepted..
Kindest Regards.
John...
Old Jul 12, 2013 | 05:16 AM
John,
I've moved your question from XK8/XKR section to X308 section.
Members here with the same model as you will be able to advise how to re-attach the High Mounted Stop Lamp.
Old Jul 12, 2013 | 06:03 AM
jimbov8's Avatar
Hi John,
Sounds like the glue on the clips has deteriorated. From memory, there should be 2 clips that are stuck to the glass and then the light fitting attaches to them.
Get yourself some good quality glass adhesive. Clean the glass with white spirit and then re-attach the 2 clips. When dry, refit the light.
Take your time and get your measurements right or you will have to do it again. It is a bit tight at the back there, it took me 2 attempts to get it done.
Hope this helps,
Old Jul 12, 2013 | 10:03 AM
Jaygee's Avatar
Originally Posted by jimbov8
Hi John,
Hope this helps,
Thanks for the quick reply Jim..
I will have to give it a try ...
regards
John..
Old Jul 12, 2013 | 10:54 AM
I haven't done this on an X308 but it sounds like the setup is the same as an X300 which I have done.
Adhesive doesn't last too long on these because of the weight of the Stop Lamp and I found the 3M double sided strips used for fixing number plates was more effective. Fix to the metal clips, trim to size and then re-attach to the screen.
Three years later when I sold the car, it was still firmly in place.
Old Jul 13, 2013 | 06:40 AM
jimlombardi's Avatar
Look at other forum thread on Rear Window Brake Light FAQ
https://www.jaguarforums.com/forum/x...ght-faq-58344/
Jim Lombardi
Old Jul 13, 2013 | 07:52 AM
Donzi's Avatar
I tried everything, finally JB quick weld was the ONLY thing that worked.
TIP: leave the metal clips attached to the brake light, otherwise..its next to impossible to get them glued back in the correct spot so the light will fit back on.
Old Jul 17, 2013 | 06:59 PM
GatorJoe's Avatar
The Florida heat finally caught up to my 3rd brake light this past week. I tried the 3M permanent mounting tape (which is double sided) and it lasted only 2 days. I'll try the JB Quick glue next.
Old Jul 17, 2013 | 09:47 PM
motorcarman's Avatar
Here is what we did at the dealer.
You can call a glass company and they will usually have the proper adhesive.
bob gauff
File Type: pdf
Shawn Svacha
Nov 4, 2019 02:47 PM
PMKimpton
Aug 3, 2019 08:22 PM
afterburner1
Dec 16, 2015 12:12 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
