L.E.D total bulb conversion XJ V8
Old Mar 14, 2010 | 08:38 AM
Sean B's Avatar
Default L.E.D total bulb conversion XJ V8
Has anyone experience of doing both interior and exterior on these cars, I'm thinking of changing every one I can. Does the BCM flag bulb failure if fitted, i.e. will they require resistors to function correctly?
I've got the dash out, and there's a wedge twistlock series of lights in the heater switchpack that are bigger than type A, and smaller than type B, odd size.
Any choice of colour/brightness on the interior bulbs?
The car is a 2001 MY (UK) 2002 MY (USA).
________
Harley-Davidson Model BA
Old Mar 14, 2010 | 06:43 PM
H20boy's Avatar
IIRC, interior bulbs are not monitored for voltage on the return, so swap away on those.
Exterior, all turns, brake, tail lamps are monitored. Backup/Reverse and Fogs are not.
I did a LED replacement project, you can find it in the Exterior section if you want to read about all of my trials and successes. (and a few failures)
Old Mar 15, 2010 | 05:42 AM
Sean B's Avatar
Located, thank you very much, I'm sure this will help!
________
full melt bubble hash
Old Mar 30, 2010 | 04:13 PM
Sean B's Avatar
I've just ordered a complete kit of l.e.d's for the interior of the XJR.
The number on the far left is for pairs, so 2 ea. means 4 lights, so its double that number.
2 ea. T10 W5W Dome Style (White) – Pair doors
5 ea. T10 W5W Inverted Style (White) – Pair rear and map and boot
2 ea. T10 6-Chip SMD Style (White) – Pair speedo
1 ea. 36mm 2-LED SMD (White) - Pair rear number plate
2 ea. 10mm/T4 Neo Wedge (Blue) – Pair heater screen dip and trip
2 ea. 8mm/T3 Neo Wedge (White) – Pair map and console
6 ea. 8mm/T3 Neo Wedge (Blue) – Pair console
1 ea. 8mm/T3 Neo Wedge (Green) – Pair console
2 ea. B8.7D Twist Lock 1-LED (White) – Pair speedo
Hope this helps - I'll be uploading pictures once installed, but it wont be any time soon!
Old Apr 10, 2010 | 12:41 PM
shl1980's Avatar
Hi Sean B,
you answered my bulb question in another thread and you suggested exchange for LEDs.
I like the Idea, and I found this info, thank for it.
I just want to ask if you made the exchange? Any important remarks?
thanks.
Old Apr 12, 2010 | 07:19 AM
Sean B's Avatar
Not yet, but Jaguar use a bulb type that sits in size between type a and type b wedgey, you have to take a bit off the sides to make it fit in the slots on the centre console upper light rail.
Will comment with pictures and results when done, but it will be a while, I've to install all electronic systems first - total rebuild into a new shell.
Old Apr 12, 2010 | 07:24 AM
ixj8it's Avatar
I am interested in doing the high mount stop lamp in LED. I took it apart recently and wow things are crispy in there.
Old Apr 12, 2010 | 07:28 AM
Sean B's Avatar
Yep done that one, ebay for a "super intelligent high spec led stop beam led sign" it's got 23 led's, and cost about £10....punch in "rear brake led" or some such search....
I just swopped the original bulb holder for this and it fits, just.
Old May 7, 2010 | 03:59 AM
shl1980's Avatar
Hi,
I received the LEDs following Sean Bs list above from http://www.bl-led.com.au.
So far I mounted the speedo once.
If I understood it correctly the T10 6-Chip SMD Style (White) and B8.7D Twist Lock 1-LED (White) were supposed to go in there.
Here is some feetback.
1) the smaller LEDs do not hold there very firmly, so far the work, but will see ...
2) the result is that the whole speedo is now blue (was green before) although the LEDs were supposed to be white.
3) (the only thing I find as real problem) not sure if it is the big or the small ones, but some are producing too pointing light. there are significant differences in the brightness of different areas of the speedo. For instance the 40 km/h and 260 km/h mark is very bright.
Old May 7, 2010 | 05:17 AM
Sean B's Avatar
Originally Posted by shl1980
Hi,
Sorry to hear this, I feel responsible....can we see a picture of the lighting? I wonder why if using white leds, its turned blue? Also why you have hot spots at 40 and 260.
It could be a change back to original spec bulbs. The 6smd leds would be of use in the headlamps, as parking lights.
Old May 7, 2010 | 06:20 AM
shl1980's Avatar
hi Sean,
you are not responsible at all. I checked the pictures of the LEDs etc. and I made the decision. If I decide to change it back, I'm sure I'll find use for the LEDs.
cheers.
Old Mar 28, 2017 | 07:58 PM
King Charles's Avatar
Sean,
Did you ever get a night pic of the dash conversion, thanks.
Old Mar 29, 2017 | 09:54 AM
Sean B's Avatar
I'll attempt some night shots this evening mate, it's been 6 years since I completed that mission!
Old Mar 29, 2017 | 11:09 AM
Yea seen that as well, figured it was a shot in the dark lol.
Old Mar 29, 2017 | 02:21 PM
Sean B's Avatar
Centre console..
Old Dec 6, 2017 | 01:22 AM
Bumping this thread for bulb info. I'm also looking for the "error free" type to avoid having to add resistors(I don't want the lingering glow from residual charge).
Just going to do the map,doors & rear reading/whites, then wait to tackle the difficult climate & cruise control bulbs.
Old Dec 11, 2017 | 04:02 PM
I really like how these LED vendors on E-Bay list item location as USA, then shipping indicates it's China. I'll be lucky if I get these bulbs before 2018.
Old Dec 11, 2017 | 04:26 PM
Sean B's Avatar
The interior lights aren't on the can-bus, the exterior lights are.
The plug and play led's available now are already fitted with resistors, but they're for a 12V rail, all the interior backlighting is 5V if I remember, it's been a while
I found most of the twistlock led's worked fine when fitted but after a while they flickered or stopped working. This called for soldering and no lighting issues since. You'll see why I soldered them when you get a look at the skinny little wires the led bulbs are meant to contact don't do it very well.
Now, led lighting has come on since I did this conversion, maybe 6 years ago so I may look into the latest SMD LED's for certain jobs on the car.
I still get enjoyment out of the switch particularly at night when it looks the best, vivid and bright against the standard weary glow of incandescent bulbs - I think it suits a dark interior. I also added backlit door pulls and footwell lighting, it gives the car more energy.
Old Dec 11, 2017 | 04:42 PM
Yea I'm just doing dome/map/readers & doors , I'll get the console at a later date. I've got a after market head unit, not sure what removing that will involve.
Old Jan 10, 2018 | 12:06 AM
I'm getting some odd effects on my front overhead console. All the incandescent bulbs worked fine, when I switch to the LEDs all work except one on the end. I rotate a known good bulb to the slot, still nothing. Any clue as to why all are working but this one holder/receptacle ?!
robbing
Mar 5, 2024 10:51 AM
mikiep
Dec 20, 2019 07:37 PM
jimforrest (uk)
Feb 28, 2019 06:42 PM
NS2000XKR
Jan 1, 2017 10:41 AM
Spazzzzzzzzzy
Oct 4, 2015 05:37 PM
