Vibration when driving intermittent with restricted performance always on
Old Jun 6, 2020 | 03:39 AM
Jagjimmy's Avatar
Default Vibration when driving intermittent with restricted performance always on
Hi I'm a new member..
I've bought an xj8 2000 reg about two years never had an issue till now recently it came up on dash asc and trac not available and restricted performance I do most of my own mechanics so I researched and after soldering the module cured that issue but the restricted pro is another I can not get my head around ? I connected the reader and found no fault codes one stored which was a coil pack which I have changed out now but still have restricted performance with no mil on tick over is fine upto 1500 revs but driving it develops what seems like a gearbox suffering where the car vibrates more revs get worse but not all the time very intermittent please any suggestions would be grateful
Old Jun 6, 2020 | 03:44 AM
As you've already posted an Intro, I've moved your question from New Member Area - Intro a MUST to X308 forum. This is the place to post technical questions about your model.
Old Jun 6, 2020 | 04:52 AM
JagV8's Avatar
Maybe changed the wrong coil or used a bad new one.
Old Jun 6, 2020 | 09:36 AM
M. Stojanovic's Avatar
Could be as simple as spark plugs. How many miles since the last change?
Old Jun 8, 2020 | 07:30 AM
Jagjimmy's Avatar
About 8000miles since plug got changed and tried 2 coils in g location which comes up on reader this morning
Old Jun 8, 2020 | 08:36 AM
RJ237's Avatar
g location?
Old Jun 8, 2020 | 10:00 AM
Originally Posted by RJ237
g location?
Yes, it is also called G-spot, after Ernst Gräfenberg who discovered it.
Old Jun 8, 2020 | 10:21 AM
Don B's Avatar
Here's a diagram showing the cylinder numbering for your engine (diagram on left). So a P0303 or P0353 DTC would suggest a problem in the third cylinder from the front of the engine in the right-hand bank (as viewed from the driver's seat), alternately referred to as Bank 1 or Bank A. The left-hand bank is Bank 2 or Bank B:
You can download the Jaguar-specific definitions and possible causes of diagnostic trouble codes here:
Jaguar X308 DTC Summaries 2000
Cheers,
Don
Old Jun 8, 2020 | 11:19 AM
Highhorse's Avatar
That depends on your perspective....its a new discovery every time I find it on my girlfriend.
Old Jun 8, 2020 | 11:25 PM
For easier reference:
Bodayga TV (BODAYGAdotcom)
Apr 24, 2017 03:08 AM
Jag u are
Mar 31, 2013 10:53 AM
mhazell61
Mar 20, 2013 09:32 PM
eneryv111
Sep 2, 2012 06:32 PM
loblue
Aug 5, 2011 05:53 PM
