XJ8 Steering Column Adjuster Switch Replacement
Old Aug 22, 2025 | 06:00 AM
larrygee's Avatar
Default XJ8 Steering Column Adjuster Switch Replacement
Does anyone have a link to a YouTube video or other information on how to replace the switch that adjusts your steering column?
I’ve looked but maybe your search skills are better than mine.
This would be for a 2000 XJ8.
Old Aug 22, 2025 | 07:45 AM
Peter_of_Australia's Avatar
SO you have the switch already?
If not, the P/N seems to be LNA6465AA
And I found a hit on ebay:
https://www.ebay.com/itm/196341251316
In regards of the installation, you might get inspiration in those 2 videos:
Old Aug 22, 2025 | 11:08 AM
Jhartz's Avatar
Also Motorcarman had an input to a thread that explained how to replace the drive belt which is what controls the to and fro
Old Aug 22, 2025 | 03:51 PM
larrygee's Avatar
https://www.youtube.com/watch?v=MNUQ...el=NorthernXJR
https://www.youtube.com/watch?v=_C26...krattedieratte
Thank you for the lead on YouTube. Yes, I have the part number. The part number you listed is for the motor and I’m gonna start by testing the switch.
Pretty sure you do not have to remove the air bag or steering wheel to access the switch.
Motor? Maybe. Let’s hope it’s not the motor..
Old Aug 22, 2025 | 04:35 PM
motorcarman's Avatar
If the REACH motor is operating but no movement, the cable is likely sheared.
If the column can be pulled/pushed in/out manually, the nylon gear teeth are sheared.(new column)
If the switch is faulty, (I have never seen this) you can remove it from the lower cowl and replace it.
Old Aug 22, 2025 | 07:50 PM
larrygee's Avatar
I don’t hear any sound from a motor when I attempt to move the column up/down, in/out.
That’s why I thought it might be the switch. That part is easy enough to install and test so I’ll try that first.
I don’t relish the idea or cost of replacing the motor.
Old Aug 22, 2025 | 09:10 PM
Addicted2boost's Avatar
The steering columns and the front seat headrests don’t like to move without breaking too much. Inherent flaws.
Old Aug 23, 2025 | 08:10 AM
There are TWO motors,
TILT is the motor easily accessed under the column.
The REACH motor is on top of the column not really visible without dropping the upper column and tilting it down.
Old Sep 2, 2025 | 02:37 PM
larrygee's Avatar
Ft59
Apr 18, 2021 08:15 PM
Roger Mabry
Jun 19, 2019 09:14 PM
hstovall1
Feb 10, 2019 11:38 AM
chris2806126
Apr 15, 2015 01:46 PM
nahidik
Aug 8, 2009 12:33 AM
