Ignition Timing
Old Jun 27, 2018 | 09:49 AM
yachtmanbuttson's Avatar
Default Ignition Timing
I cannot find the correct ignition timing when I search this forum, so looking for some advice. 1975 XJ6C, 4.2L, T/Stromberg 175's, Fireball XR700 electronic points, standard distributor with vacuum advance, all emissions equipment removed. Currently it's timed at 7d at idle by the timing light. Haven't run it on the road for the pinging sound.
Any ideas as to where the timing should be?
Old Jun 28, 2018 | 03:21 AM
I always set all mine at 10BTDC, STATIC, and then crank the advance as I drive time it, and thats it,
Never bothered with specs, or the timing light.
You will know when that engine hits the timing sweet spot.
Old Jun 28, 2018 | 08:17 AM
JagCad's Avatar
That is pretty much I and other old tech guys have done it. for years. Spec's are a "safe" factory compromise for many variables.
Grant';s method tunes to those conditions.
Carl
Old Jun 28, 2018 | 06:26 PM
ronbros's Avatar
DITTO
Old Jun 29, 2018 | 06:16 AM
iramphal's Avatar
Could Grant put together a "How To" outline as just how to set the static timing and then doing the fine tuning adjustments on the run. I think this would be a very beneficial article for the ones of us that want to do it but don't have the confidence without clear guidance. How about it Grant? My car is an 85 XJ6 SIII.
Old Jun 29, 2018 | 07:30 AM
Will do.
Working tomorrow, and bed time now, but will do over this weekend.
Old Jun 30, 2018 | 06:53 AM
iramphal's Avatar
OOOHHH! I'm so looking forward to this!
Old Jul 1, 2018 | 03:03 AM
Here ya go.
Black beast required a little TLC first up, but all good now.
File Type: doc
Old Jul 1, 2018 | 06:17 AM
iramphal's Avatar
Thank you Grant. The first thing I did was print it out for the workshop file. I'll give it a try tomorrow (Canada Day holiday) and disturb the neighbours!
Jaguar2986
Mar 9, 2017 02:47 PM
his196
Sep 25, 2014 02:52 PM
MLRocafella85
Jun 18, 2011 02:19 PM
WillieE
May 17, 2011 11:14 AM
