Tranny mount
Old Jun 5, 2016 | 12:57 PM
NathanDD6's Avatar
Default Tranny mount
Hi all
I've posted previously about a knock somewhere when I go over bumps etc, having now ridden passenger in my car for the first time, I realize it is not the front left, seems to come from the centre, hard to tell though, reverberates in the cabin. However, having been under my car, I noticed the transmission mount was slightly loose, is this right? Should it be able to flex a little like it is? I also ask because the shifter sits high, especially at the rear of the housing. Any chance something could be wrong here? The chap that changed the fluid also has a habbit of not tightening things up... Any thoughts are most welcome.
Old Jun 5, 2016 | 05:10 PM
Doug's Avatar
The mount *does* have some springy-ness but design but in all likelihood your 'thimble' cushion is worn out, #3 in this illustration
Gearbox Mounting-5.3 Litre - Parts For Series III Saloon | Jaguar Classic Parts UK
Another possible source is exhaust pipe-to-body interference
The gearshift is mounted to the floor of the car, not the transmission....so there's no relationship
Old Jun 5, 2016 | 06:04 PM
NathanDD6's Avatar
Ah thanks for clearing that up Doug, again I've learnt something new today.
#3 looks suspect to me too, I'll dive under there tomorrow and have another look. I'm doubting the pipes, the knock is a pretty deep thump, not anything light and tinny. Are these bushes known to go?
Old Jun 5, 2016 | 06:22 PM
Doug's Avatar
YES!
Old Jun 5, 2016 | 06:28 PM
Here ya go.
I wrote this years ago, hope it helps a tad.
Jaguar TH400 transmission mount explained.doc
Old Jun 5, 2016 | 06:30 PM
NathanDD6's Avatar
Wonderful, well if it solves my problem that is... I'll poke my head under tomorrow, thanks again Doug!
Old Jun 6, 2016 | 08:21 AM
JagCad's Avatar
Neither is in my car, but, I just had to look !
Two comments:
1. Yes, I use Libre Office. slick as it gets.
2. GM used a simple rubber block to do the same thing. Seems like
one would fit just right and simplify a lot.
Carl
Old Jul 9, 2016 | 04:36 AM
NathanDD6's Avatar
Just read the doco you sent Grant, very useful! Thanks! And it confirms the sound I'm hearing is the UJ clobbering something, an opportunity to stand on it from an inclined stationary start presented itself, and I could hear what you described. Now, the spacers that the service bulletin asks for, do they go between item 9 and the tranny? I've attached the diagram to help.
Many thanks
Old Jul 9, 2016 | 05:00 AM
Yep.
I used standard washers from my tin of washers. Nothing fancy needed here.
Old Jul 10, 2016 | 07:46 AM
NathanDD6's Avatar
Brilliant! Thanks Grant!
Old Jul 12, 2016 | 08:24 AM
NathanDD6's Avatar
Had a look at the mount today... How high can I jack the tranny, I'm scared of bending something... Just wanting to put spacers in, if I undo the 2 bolts at the back and jack the tranny, will it ever come away from the mount? Or do I have to remove the whole thing?
Many thanks.
Old Jul 12, 2016 | 09:15 AM
In your dreams Nathan.
That mount bracket needs to come out, which means unloading that spring, and then you can do thw washer thing.
I am still more inclined that thw "Cotton Reel" bush in the centre of that mount bracket is toast.
Greg on FrNCWE Ha done an excellant safe way of unloading that spring. It should be in here, or maybe the XJ-S section.
I will email him to put it here for you when the planets align better.
Old Jul 12, 2016 | 10:03 AM
NathanDD6's Avatar
Aha that clears things up! Thanks a lot Grant! Might as well do the whole lot in one shot...
Old Jul 12, 2016 | 06:26 PM
Here ya go, from Greg in France.
https://www.jaguarforums.com/forum/x...itting-145478/
Old Jul 16, 2016 | 06:50 AM
NathanDD6's Avatar
Thanks a lot Grant, much appreciated!
hoodun
Jun 6, 2017 06:38 PM
Mrqng78
Apr 6, 2016 11:49 AM
ETexJag
Mar 30, 2016 03:34 PM
mark campbell
Mar 28, 2016 11:30 PM
al_roethlisberger
Mar 28, 2016 04:12 PM
