XJ6 Series 2 Fuel Return Line
Old Aug 19, 2022 | 05:13 AM
E61's Avatar
E61
Default XJ6 Series 2 Fuel Return Line
Has anyone figured how to successfully run a fuel return line in a series 2 XJ6 using the original tanks? Other than swapping for series 3 tanks I'm stumped. I was going to buy a complete series 3 for the tanks but maybe there's an easier way.
Old Aug 19, 2022 | 09:56 PM
Jahmiata's Avatar
This might be easier...
https://www.welshent.com/Fuel-Emissi...IR-for-XJ6XJ12
Jeff H.
Old Aug 20, 2022 | 12:18 AM
E61's Avatar
E61
Thanks, that would be ideal but down here they want $900 each for those tanks. It's cheaper to buy a whole car and wreck it just for the tanks.
Old Aug 20, 2022 | 03:20 AM
Bill Mac's Avatar
Is your series 2 XJ6 fuel injected or running carbies?
I have never encountered an Australian delivered S2 XJ6 with fuel injection.
More information please
Old Aug 20, 2022 | 05:23 AM
E61's Avatar
E61
The return is needed for an Injected Chevy 383 stroker in my series 2. Up to now it's been running a 350 with carbs.
Old Aug 21, 2022 | 02:39 AM
LT1 jaguar's Avatar
Active Streak: 60 Days
This may be too obvious, but here's how I re-ran my pressure line. Both press/return on my non-Corvette LT1 attach on left rear of engine and the S3 injected engine had the return on that side and press on right side. I intercepted the press line in the boot and ran a new line up to the brake booster area.
If you were running a carb and the original S2 had carb's, you will need a higher pressure fuel pump(s).
Dave
Old Aug 21, 2022 | 02:59 AM
E61's Avatar
E61
Same colour as my car! Yes it has a high pressure pump. Being a series 2 there is no fuel return infrastructure to the tanks at all. My conundrum is A, how to do the return from scratch without changing to series 3 tanks if its at all possible and B, can I do it using one tank. The more i think about it its going to be easier to just buy a series 3 and strip out the tanks and return architecture. I just blank off the holes for the immersed pumps.
Old May 5, 2024 | 10:55 PM
Jahmiata's Avatar
E61 what was your finial solution?
Jeff H.
Old May 7, 2024 | 09:21 PM
slofut's Avatar
Jeff, your series 2 carb tanks should have a plugged return port beside the outlet. It may be small but on an sbc I'd probably run 'em. I can take pics if needed.
Also, this will prob be helpful whichever way you go... https://www.welshent.com/Fitment/Dai...nk-Adapter-Kit
Sorry, I'm confused on who the OP is. E61 needing help and has a series 2 carb car with internal low pressure pumps correct?
Old May 8, 2024 | 07:17 AM
Thorsen's Avatar
This thread is almost 2 years old - I hope by now they figured it out!
Old May 10, 2024 | 06:55 AM
slofut's Avatar
Geez... I did it again
Jag7651
Nov 21, 2021 08:37 AM
mikega
Nov 7, 2021 03:36 AM
rdssdi
Oct 28, 2021 07:46 PM
INDYJAG-84
Sep 21, 2021 08:12 AM
Mattandbec1
May 2, 2020 02:04 PM
