Horn blares . . Help
Old Jan 8, 2015 | 10:48 PM
Lance 99's Avatar
Default Horn blares . . Help
I have a 1987 XJS Coupe. I have searched all of the posts I can find and Kirby Palm's book re: horns staying on and I still can't figure out what the problem is.
I was told that if the steering wheel isn't tight and the hex shaped nylon piece that is attached to a copper rod isn't tight that this could be the cause. I am stumped. I looked at mine today and the copper rod and the steering wheel were both tight. I loosened up the rod and took it out at it looks like brand new. Without the horn pad on the steering wheel if i use the telescoping ring and slide the steering wheel in, even just a little, the horn blares. If i extend it all the way out and locks it, it stops. Thats where I have it locked now and then the horn pad works to activate the horn.
Any ideas where I should look next?
Old Jan 9, 2015 | 01:48 AM
Greg in France's Avatar
Horns work by the circuit being live all the time and when you press the horn it earths the circuit and makes the horn work. You have a short in the column. If it is affected by whether the wheel is in or out on the adjuster, that is a good pointer to where the short is. Sadly, it could well be in the insulation inside the column, as when the wheel is fully in, the horn rod with the nylon nut is in a different position within the column. If this is so, a columns change is the best solution as th insides are not get-at-able. A column chnage is not that hard, actually.
It is worth removing all the column trim around the rear of the wheel though, and seeing if anything is grounding when you move the wheel.
But before you do that, have a look above where yuor shins are, by relmoving the under dash panel. You will see a couple of copper wipers running against the column attached to loom wires. See if one or other of these is touching anything.
Greg
Old Jan 9, 2015 | 09:29 AM
Lance 99's Avatar
Thanks - I will check it out this weekend
Old Jan 9, 2015 | 06:22 PM
Flint Ironstag's Avatar
Default Ha ha!
You can read my many funny (now - embarrassing then) threads on this very subject.
Quick fix is to snip the wires at the horns, but that is unsafe if you have to drive any distance.
Old Jan 9, 2015 | 11:29 PM
Lance 99's Avatar
Default Has anyone had to replace these yet?
In the picture I noticed these parts (#2 & #3) further down on the steering column having to do with horn earth contacts. Has anyone replaced these yet?
Attached Thumbnails Horn blares . .  Help-screen-shot-2015-01-09-11.24.51-pm.png
Old Jan 9, 2015 | 11:40 PM
Lance 99's Avatar
https://www.jaguarforums.com/forum/x...column-120046/
I think I'm on the right track . . . hopefully it warms up over the weekend so I can check it out.
Old Jan 9, 2015 | 11:57 PM
Doug's Avatar
Those are the 'wipers' Greg was mentioning
Old Jan 10, 2015 | 03:58 AM
Brake buster's Avatar
the mounts for these can become loose and cause a short or open circuit resulting in horn problems
the parts shown above are available brand new from jaguar for about $10 each , or less
they are fiddly to refit, but it can be done, as i have replaced my own
this will no doubt be your issue with a continuous horn
BB
Old Jan 10, 2015 | 09:19 PM
warrjon's Avatar
My bet would be the spring that connects the rod running down the column to the lower wiper. If you pull the connector out of the lower wiper does the horn stop?
I had a similar issue with my horn. Check out my blog, it has the first repair, and how to disassemble the column. As usual with these it failed again. I ended up removing the rod from the column and running a wire (silicone insulted) down the column.
Old Jan 10, 2015 | 09:49 PM
Lance 99's Avatar
Wow - that looks way beyond my skill level. I can't really see what's going on down there when I crawl under the dash. I don't even see anything to disconnect from the wiper.
I think for the time being I am going to leave the steering wheel ring locked as far back as it takes to stop the horn from honking and re-visit this when I have more time getting to know the car.
Old Jan 11, 2015 | 11:41 AM
Lance 99's Avatar
Did you leave the nylon hex beyond the steering pad and just cut off the rod and solder a wire to the back of that? If so, where did you solder the other end of the wire?
Old Aug 2, 2024 | 07:51 PM
teags's Avatar
Hi there…I have a continuous horn issue on my xj6 series 3 and after reading this thread looked under the dash at the column wiring and found this purple wire nicked and wondered if that could be my issue? If so, this wire is long enough that I could trim it to remove the wire after the nick and take the original contact and put it onto the cut wire and then reuse. Any feedback would be greatly appreciated! Thank you.
Old Aug 3, 2024 | 02:10 AM
The nick in itself, unless bare wire at the nick was shorting to earth, would not cause it. You can easily test for this by connecting the bullet and taping up the nick and seeing if the fault remains. There are lots of possibilities:
  • short at the actual horns
  • stuck relay
  • short at the horn button
  • short in the column itself where the long contact rod goes down the centre. The ideas earlier in the thread give you some info about this type of fault
  • loom short somewhere
It is a matter of testing and examining each part of the system between connectors to test for continuity.
nickr76
Oct 21, 2023 01:02 PM
Duke85
Jun 12, 2020 04:32 AM
Robbo9
Feb 13, 2019 03:34 PM
Karel Deppe
Aug 27, 2014 02:43 PM
hamiltonian
Mar 8, 2014 12:28 PM
