V12 Throttle Body sync made easy
Old Jul 26, 2012 | 05:28 AM
warrjon's Avatar
Default V12 Throttle Body sync made easy
Just thought I would add this how to - it can be difficult to get the throttles properly synchronized running from one bank to the other.
This makes adjusting throttle body opening easy.
First step is to adjust ONE throttle for 0.002" clearance at the top between the butterfly and housing with the throttle closed. Then remove any backlash in the rod. I did the left first.
The first pic shows inserting 2x 2mm bits of steel to hold the throttle slightly open.
Next pic is the LH throttle body stop measured with feeler gauges with the 4mm shim in the pedestal. Once this was done I moved to the RH side and set the opening the same with feeler gauges.
Now both throttles open within a poofteenth of each other.
Attached Thumbnails V12 Throttle Body sync made easy-dscn0027.jpg   V12 Throttle Body sync made easy-dscn0029.jpg   V12 Throttle Body sync made easy-dscn0031.jpg   V12 Throttle Body sync made easy-dscn0025.jpg
Old Jul 26, 2012 | 05:37 AM
JameyXJ6's Avatar
so if you have the throttle shimmed at 4mm, are you setting the throttle bodies at 4mm?
Old Jul 26, 2012 | 05:47 AM
warrjon's Avatar
No - the shim in the throttle is only to open the throttles so a measurement can be made. Each throttle is then adjusted so they are the same distance from the stop.
I'll edit the post it is a bit confusing.
Old Jul 26, 2012 | 05:51 AM
JameyXJ6's Avatar
ahh...got it...okay that makes sense now.
Old Jun 28, 2020 | 10:52 PM
AttyDallas's Avatar
I've bought a pair of those black throttle bushings that are supposedly often cracked, missing, etc. on our 5.3s, but could not figure out where they go. Looking at your pics, in #3, is that the bushing toward the bottom?
Old Jun 29, 2020 | 03:26 AM
Bloody well done.
That "poofteenth" is going to drive Google nuts. AAH the Aussie lingo, so special.
Old Jun 29, 2020 | 07:12 AM
Greg in France's Avatar
Start at the capstan, follow one of the rods to the end of the manifold, here you will see the lever the throttle rod is pushing is fixed to the throttle butterfly actuating rod running forwards to the throttle body.
You will see that the cabin end of this butterfly actuating rod is set in a hole in a triangular bracket. It is into this hole that the black throttle rod bushing fits.
Old Jun 29, 2020 | 10:46 AM
Dukejag's Avatar
How much free play do the throttle rods have when the throttle s closed?
Old Jun 29, 2020 | 05:21 PM
ronbros's Avatar
i do that differently, i get the engine up to temperature after a rough setup, and heat gun measure down pipe temps, NO catalyics!
then adjust linkage slowly to get them even temps, make a drive and measure again, sometime a slight readjust!
works for me?
a made bushings from aluminum rod, and a lathe, any small shop could do them!
Old Jun 29, 2020 | 11:18 PM
wrightbenz's Avatar
the bushing fits on the end of the shaft near the linkage. Yours are probably completely gone mine were. The shaft was just loose metal to metal. The bushings I bought did not fit without turning down one end so they would pop in. I put them on and easy out in my drill and spun it against a file into they fit.
hope this helps.
Old Apr 26, 2025 | 10:51 AM
BradsCat's Avatar
It is easy to remove the housings from the manifold, Insert the new bushing and then slide the rod thru. Re-attach the housing to the manifold. 5-10 minute job.
Old Apr 26, 2025 | 11:05 AM
BradsCat's Avatar
I am confused about setting the butterfly valves to .002 clearance.
How does using 2mm or 4mm shims assist this process.
I unhooked the rods and opened the butterfly by hand inserting the feeler gauge at the top. The feeler gauge should be able to just pull thru the butterfly.
Next I adjusted the set screw until it contacted the stop. Locked it down with the set screw.
Repeated procedure on other side.
Finally, adjusted control rods to fit without slop when the capstan is turned. Immediate throttle response.
Last step is to adjust the idol. Don't forget to use the AAV to finalize the idol.
Old Apr 3, 2026 | 03:11 AM
osyris's Avatar
RESOLVED -!
Gentlemen , the problem was indeed that the butterfly was basically cemented to the body and was not moving at all, I had to put significant pressure on the butterfly for it to pop loose.
It seems to me that I used electrical contact cleaner to clean the throttle , as that's all I had with me at the time. Electrical cleaner I said to myself was more gentle than throttle cleaner ...but...it seems it was too gentle and the solvent allowed the varnish & gunk to microscopically re-
cement it's self at the edges of the butterfly.
So yes , on a S type 2000 3.0 the butterfly moves if pushed with the fingers and do not use electrical contact cleaner , it microscopically cements the butterfly shut. This caused the throttle butterfly to fail to open , resulting in a loud buzzing sound from the throttle body motor.& A fail safe mode dash display .
I want to thank the gentlemen above for taking the time to help me out ....my sincerest thanks 🙏.
The car is now good for 100000km , EVERYTHING has been redone that's serviceable.
Regards
Peter
Old Apr 3, 2026 | 03:45 AM
ptjs1's Avatar
Peter,
i think you meant to post this in your thread in the S-Type section.
Paul
Crandell
Mar 21, 2019 11:44 PM
fredd60
Mar 10, 2019 09:01 PM
chrisleg
Nov 27, 2018 12:37 AM
Neil1664
Nov 2, 2015 12:26 PM
