XJS crank sensor test
Old Dec 23, 2017 | 04:02 PM
Jerey's Avatar
Default XJS crank sensor test
How do I test a crank sensor for my Jaguar xjs 4 litre.
It will not start, spins over. It did run briefly.
Thank you
Old Dec 23, 2017 | 04:33 PM
Lawrence's Avatar
Well this is the XJ40 forum -but- as the XJS 4 litre has the same motor as the 4 liter XJ40's, you can get an idea if it's working buy cranking the engine and looking at the rev counter.
If it doesn't register any RPM when cranking, the crank sensor is suspect
Larry
Old Dec 24, 2017 | 01:42 AM
frenchfairplaydriver's Avatar
Default Crank sensor
Hello,
Perhap’s This tech Doc may help you ?
Bestregards
Old Dec 24, 2017 | 10:00 AM
Don B's Avatar
Hi Jerey,
Welcome to the Jaguar Forums! It's great to have you with us.
I have moved your thread from the forum for the XJ40 to the forum for the XJS. Here you will find knowledgeable owners of similar cars.
Larry and frenchfairplaydriver have already given you some excellent information. The classic test Larry describes of watching the tachometer/rev counter while cranking will give a good clue as to the health of your crankshaft position sensor (CPS). Just to expand on his instructions: if the tachometer reads approximately 200 rpm while cranking the engine, the CPS may be working properly, at least intermittently. If the tachometer reads 0 rpm while cranking, then either the CPS or its electrical circuit has a problem.
You don't mention the year of your XJS, but you can download the appropriate Electrical Guide at this link:
JagRepair.com - Jaguar Repair Information Resource
Besides the CPS, there are plenty of other possible causes of of a cranks-but-won't-start condition. The fuel pump, fuel pump relay and fuel pump electrical circuit are key suspects. Turn the key to position II (ON, but do not start the engine), and listen for a short priming burst from the fuel pump. If that is inconclusive, loosen the fuel line at the firewall/bulkhead end of the fuel rail, aim the fuel hose into a suitable container, and crank the engine briefly while observing the fuel flow from the line.
Other suspects are the ignition coil, distributor cap and rotor, and other associated ignition components. You can remove a spark plug, reconnect it to its wire, and lay it on the cylinder head cover so the threaded sleeve is grounded. Crank the engine and watch for spark.
Please let us know the year of your Jag (it's helpful if you add the year, model and engine details to your signature line so others don't have to ask).
Also, please visit the New Member Area - Intro a MUST and post a required introduction so we can learn something about you and your Jaguar.
Cheers,
Don
Old Dec 24, 2017 | 10:29 AM
sidescrollin's Avatar
Confirm spark and fuel and move on from there. Not any particular reason to jump to the crank sensor if its not starting but you haven't gathered any info about the fuel and spark.
Old Dec 24, 2017 | 12:46 PM
Jagsandmgs's Avatar
I’m all for diagnosing problems... but it’s ALWAYS the CPS. Always! Conventional troubleshooting diagrams just go out the window. Step one, replace the CPS. Step two, anything else.
My 95 4.0 XJS has eaten no less than five in the last 100k miles. I keep a spare in the glovebox.
If you buy a CPS, install it, and the car won’t start... put the old one back on and leave the new one in your glovebox. You’ll need it eventually.
Old Dec 25, 2017 | 05:10 PM
I can't imagine the car not starting, so you go through all the trouble of replacing the CPS only to find out you have a bad fuel relay. If you try to skip diagnostic steps, you are in for a bad time.
Old Dec 25, 2017 | 07:45 PM
macdoesit's Avatar
Banned
I would no way disconnect the fuel hose and crank the engine, what if it did start and catch fire.
I checked my fuel pump by aiming hose into container and turn ignition on and it did squirt gas but (do not crank) the engine.
Old Dec 25, 2017 | 08:39 PM
Don B's Avatar
You'll only get a short priming burst from the fuel pump when you turn the key to position II (ON), which is not usually sufficient to judge fuel flow. Obviously, you should follow good safety practice and keep the fuel hose and catch container away from sources of potential sparks. But even if the engine starts while the fuel hose is disconnected, it is not going to run for long with no pressure to the injectors. I've cranked engines countless times with the inlet fuel hose disconnected. In roadside emergencies, I've even done it without a catch container and simply aimed the fuel onto the ground (avoiding any hot exhaust components). This is often the fastest method for confirming the fuel pump is not only running but is delivering sufficient fuel flow. An alternative to cranking the engine is to jump terminals 30 and 87 in the fuel pump relay socket.
Cheers,
Don
Old Dec 25, 2017 | 10:31 PM
orangeblossom's Avatar
If you pull the middle wire out of the Distributor then the Engine cannot start as you Crank it over
With a 4.0L XJS it is highly likely that you have an 'in tank fuel pump' and if that should need replacing, then the Fuel Tank would need to come out
Or at least be pulled back far enough to be able to get to the Fuel Pump that's in the Top of the Tank, which is a PIA Job if ever there was one
So in the event that you're not getting Fuel, then the First thing to check is the Relay, which on a (UK) Car is accessible from inside the Boot/Trunk
Behind a Piece of Trim up by the Bulk Head, where it is tucked up out of sight, in the space under the Rear Wing/Fender (inside the car)
Old Dec 26, 2017 | 04:08 AM
warrjon's Avatar
To fix any problem you need to work methodically through each system and verify it is working. An engine only needs Air, Fuel and Spark at the correct time to work.
Verify you have spark by removing the dissy input and holding it close to the engine block or other good ground. If you have spark then the CPS is most likely working as the ECU uses the CPS to time the spark.
Fuel can be verified by either a pressure gauge or cracking the fuel line at the input to the rail.
Also check the battery voltage if it is low this could prevent starting .
Old Dec 28, 2017 | 08:04 AM
scarbro2011's Avatar
Hi!
Be sure to check the fuel tank inertia shut off switch.
My 1994 has the switch in the passenger (RH) door jam.
Also check the fuse for the ignition coil and the fuel pump.
I had a strange problem where the ignition coil fuse almost opened up.
It was acting like a spark gap/resistor. The car would have a spark and then nothing.
Use an Digital Volt Ohm(DVM) meter to check those fuses. The good old
Mark One eyeball doesn't work very well on checking fuses.
Regards,
Bob
Old Dec 29, 2017 | 11:49 AM
El Gato's Avatar
Just had this turning over / not starting issue problem with my 96 XJS - replaced the fuel pump relay and all is fine. Cheap, quick and easy place to start and it is a well known fix.
Old Dec 30, 2017 | 01:12 PM
Simply_Performance's Avatar
Its difficult to test the crank sensor. I would only recommend fitting a genuine one. And crank sensors can break up so sometimes work and not. We have had them where it feels like the car has a rev limiter and it has turned out to be the CPS.
Best to just try a good used and if its not then you have a spare.
Good luck.
Old Oct 27, 2024 | 04:15 PM
Jaguaralfonso's Avatar
Default xjs 6.0 1994 Pump N1
Originally Posted by Don B
Hi Jerey,
Cheers,
Don
Very interesting information.
On my 1994 XJS 6.0 ,pump N1 turns on when the ignition is turned on, but only continues running for 3.5 seconds.
Is it normal that it does not continue running, even if I loosen the injection rail connection fitting? the flow that comes out during that time is great...
I expected it to continue pumping until the circuit reached a certain pressure or the regulating valve began to return fuel to the return...
Thank you
Old Oct 27, 2024 | 07:44 PM
Doug's Avatar
I have no 6.0 experience but the 5.3s operate as you describe: a 2-3 seconds "prime" function with key "on" before the ECU cuts the circuit.
The circuit is brought to life again when the starter is engaged and, of course, while the engine is actually running
Old Oct 28, 2024 | 01:02 AM
Hi Jerey
You have got the 4.0L XJS with 'One' Fuel Pump
Disconnect the Fuel Line from the Fuel Rail (Counter Torquing it so you don't break anything) Then hang that Fuel Line over the Side of the Wing/Fender and then push that Fuel Line into a Wider Tube, so its long enough to go into a Container
Then Crank the Engine, at which point Fuel should come gushing out continuously as the Engine is being Cranked
Not just a Dribble but like a Garden Hose
If that doesn't happen, it could be one of 3 Things
(1) Crank Sensor (Most Likely)
(2) Fuel Pump Relay (Could Be)
(3) Water Temperature Sensor (Maybe) Try the Paper Clip Trick (Pull the Plug Off) then use a Paper Clip to Bridge the Wires in the Plug and Fool the ECU into thinking that the Engine is Up to Temp
(3) Fuel Pump (Hope Not!) or that will Spoil Your Day!
Most Likely the Crank Sensor! they very often go wrong for almost no reason at all (lots of us Carry a Spare one in the Glove Box) It's really that bad
Cheap as Chips on Amazon £23 and they are not 'el cheapo' but a well known make
If all else fails, have a look at my Thread 'Carmen Won't Start' Almost every trick in the Book to Start my AJ16 4.0L Engine in my XJS
Good Luck
Alex
Old Oct 28, 2024 | 03:33 AM
ptjs1's Avatar
OB,
Note that this thread has been diverted from its original 2017 subject, yesterday by jaguaralfonso who is asking about a 6 litre.
Paul
Old Oct 28, 2024 | 05:37 AM
Hi Paul
Yeah! I wondered about that but in any event it might help somebody else
JimC64
Sep 22, 2025 02:52 PM
KenAdamson
37
May 26, 2020 04:40 AM
Don B
General Tech Help
17
Aug 8, 2017 09:11 AM
xjack
XJ40 ( XJ81 )
Oct 16, 2016 09:27 PM
Jeff DeVere
Oct 13, 2016 07:00 AM
