XJS Gear Selector sticking
Old Jan 23, 2025 | 03:50 PM
BruceVT's Avatar
Default XJS Gear Selector sticking
Many times the gear selector of my 1995 XJS gets stuck in park and will not shift. If I pump the brake enough and work the shifter will eventually go into gear. Anyone have this happen and know how to repair it.
Old Jan 23, 2025 | 04:21 PM
ptjs1's Avatar
BruceVT,
Very possible that it's the brake pedal switch that is not allowing the signal. Failing that, the rotary switch could be the reason. IME, very unlikely that it's the shift selector itself.
Start by looking at the brake pedal switch continuity, Could just be a loose wire.
Paul
Old Jan 24, 2025 | 02:31 PM
BruceVT's Avatar
Thank you,
I will try that.
Old Jan 25, 2025 | 10:21 AM
RickE's Avatar
The solenoid for the Park release is under your shifter console (ski slope) at the very front. In an emergency, you could remove the ski slope and operate the release mechanism. My 95 occasionally does the same thing so let us know if you figure it out.
Old Jan 25, 2025 | 01:31 PM
BruceVT's Avatar
That’s great information. I have removed the wooden panel but I do not see anything at the front. Do I need to remove the entire console to access it. I really appreciate all of your help.
Old Jan 25, 2025 | 03:16 PM
RickE's Avatar
When it works, you should be able to hear the solenoid under the panel forward of the gear shift handle at the front edge of the panel. You do not have to remove the console.
Old Jan 25, 2025 | 03:35 PM
RickE's Avatar
Old Jan 25, 2025 | 09:55 PM
BruceVT's Avatar
So helpful!!! Thank you so much. I hope that it is the problem because I am 70 and not as limber as I used to be to get under to the brake pedal switch. I keep forgetting that it has been 25 years since I restored my E-Type.
mrs_sutsie
XF (X260)
May 12, 2023 01:47 PM
93xjs6cyl
Nov 21, 2022 03:11 PM
Fad-Jag
XF (X260)
Sep 3, 2020 07:22 AM
spuddyo
Apr 11, 2016 11:11 AM
269kazoo
Jan 4, 2015 04:26 AM
