ABS pump motor for 1997 XK8
Old Jun 26, 2022 | 04:41 PM
Don Elliott's Avatar
Default ABS pump motor for 1997 XK8
I have code C-1095 showing which is ABS Pump Motor failure and am searching for a replacement part for my MJA 5920 BE pump. The car is a '97 XK8 with Traction Control with a 5 pipe ABS system.. Ebay has lots of ABS pump motors advertised but none are an exact match. The closest I can find is a MJA 5920 AF.
Are there other pumps that will cross over? The usual sources have come up empty, of course.
Old Jun 26, 2022 | 05:43 PM
michaelh's Avatar
Don,
A C1095 code is usually caused by failing solder joints at the pump motor connectors inside the ABS module. Have you had that repair done previously?
Old Jun 26, 2022 | 07:31 PM
Default Solder joints
Ah yes the infamous solder joints. Sadly yes they have soldered, re-soldered, finally the ABS control module was discarded and a good one was found (no small task). I've been chasing this for 5 years with no success. Now we have the pump alarm. Formerly it was a Wheel Speed Sensor which it was not. Finding and replacing this pump is my last hope.
Old Jun 26, 2022 | 09:41 PM
motorcarman's Avatar
Unplug the pump connector from the module and apply power to the two pins.
If the motor spins, (I have never seen one that did NOT) the motor/valve block is NOT the problem.
Old Jun 27, 2022 | 11:45 AM
Default What if it is not the pump?
Assuming for a moment that the alarm code is wrong and the ABS pump motor is just fine where do I look next? The gent from Jersey said this code usually means the solder joints are bad. But that repair has already been tried more than twice and the module has been replaced too. So is this failing actually fixable? I've been trying for five years with no success. I'm losing hope as thousands have been spent in chasing this. .
Old Jun 27, 2022 | 11:54 AM
Check the wires from the pump motor to the 2 pin connector.
The insulation tends to fall off old wires and can cause a 'short-circuit' if the bare wires touch each other.
Old Jun 27, 2022 | 01:17 PM
Default Wires look fine
Well phooey, the wiring on the ABS pump looks like new. So that is unlikely to cause my issues. Is a pump failure a common concern or is it rare? Since I cannot find a match for the MJA 5920 BE part number are there any others that will work? Alternatively I can just continue to drive it without the ABS function and give up trying to fix it.
Old Jun 27, 2022 | 03:23 PM
You have a 5 pipe (6 VALVE) pump motor/valve block.(except traction control)
I suspect a 1998/99 XK8/XJ8 unit of the same build will work?
Just don't try a 6 pipe (9 VALVE) unit.
Like I stated, "I have never seen a failed pump motor/valve block" but........................
Old Jun 27, 2022 | 03:37 PM
Default But mine has traction control
My machine has traction control (there's a button on the dash to turn it off). Now what can I do? It is looking to be quite hopeless.
warren8959
Jan 21, 2024 05:06 PM
jhshannon
May 14, 2023 04:02 PM
Jeff.Jag
Jan 26, 2020 12:23 PM
William R. Johnson
Jan 16, 2013 06:34 PM
Joffa
May 14, 2009 08:23 AM
