Carfax info, surprising
Old Nov 23, 2009 | 04:23 PM
brgjag's Avatar
Default Carfax info, surprising
Did the carfax on my 97 xk8 and foudn that there were several, 3 or 4 reports of the THROTTLE BODY being cleaned. I find that odd that it was done that much , much less reported to carfax. Can I clean it myself? If so, with what?
Old Nov 23, 2009 | 04:59 PM
test point's Avatar
There were several issues with the TBs of the '97/'98 cars none of which were fixed by cleaning. May have been wishful thinking on the part of a dealer.
The TB can be easily cleaned using a product designed specifically for that. Do not use a 'carburetor' cleaner.
There is an excellent pictorial on another forum on the process. http://tiny.cc/7U3Ip Under 'ARTICLES'
Old Nov 23, 2009 | 06:40 PM
hlgeorge's Avatar
Do I remember correctly that there is a free replacement on the TBs for early model cars, but must be done by the end of 09???
Old Nov 23, 2009 | 07:01 PM
Gus's Avatar
Gus
You are correct Lew, that is if it has the correct vin# and you get it before the end of December. If you elect not to have it checked by that date it could be a $2000.00 mistake!
Old Nov 23, 2009 | 07:23 PM
brgjag's Avatar
MY 97 could have the TB replaced?? How do I know if mine qualifies
Old Nov 23, 2009 | 07:33 PM
Gus's Avatar
Gus
Go to this web page http://www.xclusively-jaguar.co.uk/xj04_fandi.html It will cost you! You will need to tell us how you make out.
Old Nov 23, 2009 | 09:07 PM
brgjag's Avatar
how will it cost me if it is free???? Changing FOC???
Old Nov 23, 2009 | 09:25 PM
Gus's Avatar
Gus
It is free if you act on it before the deadline of Dec. 2009
Old Nov 24, 2009 | 04:33 PM
dbright's Avatar
Per the Service Action S514 doc, a '97 XK8 appears to qualify only for a ECM Reprogram vs. Throttle Body Replacement. Still can't beat FOC...
From a door sticker, I see my (recently acquired) '97 XK8 had "S819-Reprogram ECLC 3-8-99 for misfire detection." ECLC related to ECM? Sounds like a ingition control deal. Sorry, I gotta lot to learn...
sadepol01
16
Nov 22, 2024 05:05 PM
King Charles
Oct 16, 2015 01:25 AM
10 XF Premium
Oct 2, 2015 09:22 PM
inactualis
Oct 2, 2015 11:13 AM
Johnken
Oct 1, 2015 05:07 PM
