convertable A pillar trim removal
Old Feb 9, 2013 | 09:16 AM
RaceDiagnostics's Avatar
Default convertable A pillar trim removal
Does anyone know how to remove the A pillar trim, I plan to remove mine to try to repair the peeling rubber, see below.
Attached Thumbnails convertable A pillar trim removal-%2520pillar%2520trim%25202.jpg
Old Feb 9, 2013 | 09:23 AM
Jag#4's Avatar
Here's a Reverend Sam video on the interior A-pillar inside trim. Try a search for the rubber trim replacement. Should be common to most vehicles.
Old Feb 9, 2013 | 09:28 AM
Badger's Avatar
Mine has gone the same way, both sides. I too would like to find a cure for this, it is the only thing that spoils my car!
Old Feb 11, 2013 | 02:30 PM
Just managed to source a good set from a clean California car for £85 inc shipping, so the refurb willl go on the back burner for 10 years or so.
If anyone can say the best way to remove the door seal without damaging it to get to the trim securing screws it would be appreciated.
Old Mar 24, 2020 | 06:44 AM
xkr_dougie's Avatar
Fantastic! Exactly what I was looking for! Also suffering from the "smoking pre-owner syndrome"....
Old Mar 24, 2020 | 04:11 PM
frankc's Avatar
Confused. Outside trim or inside trim?
I have done both. Do NOT buy replacements from dealership.
Old Mar 24, 2020 | 04:19 PM
frankc's Avatar
This one? https://www.jaguarforum.com/showthre...=1#post1001829
Old Mar 25, 2020 | 01:16 AM
xkr_dougie's Avatar
....inside trim obivously ;-)
Old Mar 25, 2020 | 03:42 AM
frankc's Avatar
Yours is obviously the inside trim but if you look at post #1 it clearly shows the outside trim. Hence the confusion. Hence not obvious.
Glad you got yours sorted though,
Old Mar 25, 2020 | 05:03 AM
aeginc77's Avatar
I just recovered mine. Very simple. The pillars just pull off. They are held on with clips.
Old Mar 25, 2020 | 06:14 AM
Originally Posted by RaceDiagnostics
Just managed to source a good set from a clean California car for £85 inc shipping, so the refurb willl go on the back burner for 10 years or so. .....
Jim,
The dreaded INFINITE SCROLL has brought this ancient thread back to the surface!
As it's now more than 7 YEARS since you posted the question and the resolution, how are the replacement WINDSCREEN FINISHER's standing the test of time?
Old Mar 25, 2020 | 06:23 AM
xkr_dougie's Avatar
I apologize if I should have that brought this up unjustified... but I have to admit that I'm one of those who use the forum search function intensivly before asking ;-)
In this case I was really glad I found that video, because I was totally unsure how to remove the a-pillar trims without damaging them.
Gary A
Dec 30, 2019 10:58 PM
XJR033
Oct 16, 2018 05:45 AM
sanchez
XJ40 ( XJ81 )
Mar 20, 2018 06:26 AM
jaglover123
May 1, 2015 10:22 PM
lexoman
May 9, 2011 08:21 AM
