Coolant leak, fitting at top of octopus hose, one way valve
Old Aug 31, 2015 | 09:53 AM
Ophitoxaemia's Avatar
Default Coolant leak, fitting at top of octopus hose, one way valve
The leak is at the weird looking fitting on the right hand (looking in from the driver's side) of the top T of the octopus hose. A valley hose connects to the left and the top to the throttle body.
I found a reference to someone replacing just this T and driving 21K miles without a problem.
I'm considering cutting the hose and replacing with a standard T, but I've read something about part of that fitting being a one-way valve.
Can anyone confirm this is true, what is its purpose, and what is the effect of removing it?
My alternative is to replace the octopus hose. Worth the extra trouble?
Old Sep 2, 2015 | 07:25 PM
I took apart that section of the hose and removed the T fitting there. I replaced the o-ring on the Norma connector, cleaned and replaced everything. Haven't had a chance to test run it yet, but now at least it doesn't drip just sitting there.
Old Sep 3, 2015 | 06:29 AM
cjd777's Avatar
Good on replacing the "O" ring, but you state you only removed the T fitting. What did you find on the one way or was it a clear path for water and did you replace it with something?
Wayne
Old Sep 3, 2015 | 06:54 AM
WhiteXKR's Avatar
The one way valves are the black plastic tubes with directional arrows embossed on them.
Old Sep 3, 2015 | 10:59 AM
The t fitting I removed contained no valves.
Old Sep 3, 2015 | 05:28 PM
Jag#4's Avatar
Not sure we are talking about the same T-fitting, but follow this thread for my adventures with replacing the "T" in that area I broke while fitting another part.
I was able to have a friend make up a new fitting from aluminum, although some members have had luck at the local plumbing supply.
Been running great for over 2000 miles now with no leakage or coolant issues.
Hope this helps.
https://www.jaguarforums.com/forum/x...s-hose-145013/
Old Sep 4, 2015 | 06:42 PM
GordoCatCar's Avatar
Default Tried the Temp Fix but ended up doing the Proper Fix.
I tried to repair just the leaking section with a plastic T fitting, but it began to leak shortly thereafter. The complete octopus replacement is not that difficult and I would suggest you do the same. Get a cable actuated clamp tool to make the job much easier.
Old Sep 14, 2015 | 02:40 PM
Update: A few weeks later. Replacing the o-ring has fixed this leak at the Norma connector.
sogood
Sep 15, 2015 07:35 AM
Raul Lara
Sep 14, 2015 07:31 PM
KarimPA
Sep 3, 2015 07:32 PM
Bcrary3
Sep 3, 2015 03:48 PM
OkieTim
Sep 2, 2015 12:48 PM
