DSC fault
Old Dec 25, 2015 | 12:35 PM
Loxmth's Avatar
Default DSC fault
What the heck is that
Old Dec 25, 2015 | 12:43 PM
jimangle's Avatar
Stability control. Do you get any other faults?
Old Dec 25, 2015 | 12:51 PM
jimbov8's Avatar
First place to check is your battery.
Old Dec 25, 2015 | 04:25 PM
Loxmth's Avatar
Yes. Gear box fault. New battery always on a tender. Been having no starting problems. Checked all connections in the trunk. All tight.
Old Dec 26, 2015 | 09:11 AM
Loxmth's Avatar
Wait I don't have stability control.
Old Dec 26, 2015 | 10:12 AM
JagV8's Avatar
Car thinks it has...
Old Dec 26, 2015 | 12:46 PM
jimangle's Avatar
Does your window position memory ever fail? Meaning do your windows ever fail to go back up after you close the car door? Usually this is the first sign of battery problems followed by DSC and ABS failure. The car may start with no problems.
Old Dec 27, 2015 | 12:57 PM
Loxmth's Avatar
Never any window problems unless I do a hard reset which I have to do EVERYTIME after the no start problem. When I say no start I don't mean turns over I mean everything acts dead. Clicking noise in trunk. Dash light flashing dimly. I can tell it's going to happen when I hear a fast clicking noise in the dash near the fuse box.
Old Dec 27, 2015 | 01:00 PM
jimbov8's Avatar
Check your ground points first, start from the battery and work forwards.
Old Dec 31, 2015 | 05:07 AM
jimangle's Avatar
Make sure you wire brush the inside of your battery terminals. I have seen it on a few cars where they may look clean but there is a film that will build up and can cause exactly what your car is doing.
Jim
jagastruckerhoodornament
Mar 29, 2015 08:21 AM
marvin.d.miller
Dec 17, 2014 07:44 PM
Justicejamesb
Sep 14, 2013 08:28 AM
Toller
45
Mar 14, 2011 12:28 PM
