gearbox fault
Old Nov 20, 2008 | 04:57 PM
H20boy's Avatar
Default RE: gearbox fault
Where are you located mcleist? From what you describe, the problem sounds pretty severe. I won't speculate though. Hope you get another tech opinion soon.
Old Oct 22, 2009 | 09:44 AM
Gordo's Avatar
Default Gearbox Fault
I feel your pain Brother. I am having the same issue with my 97 XK8. In searching the forums I have seen everything from check the electrical fuses and connections to an A drum replacement within the transmission. One guy had luck with disconnecting the batt. Tried that one and the car drove great, I was very happy untill I placed the car in park. Light came on again. Im calling my mechanic next. If I find anything in my searching I will let you know. Please do the same. Cheers,
Old Oct 22, 2009 | 01:59 PM
Gordo's Avatar
Got back from my Mechanic with a working car.... so far. My problem was apparently a low Batt . Im in Canada and its getting colder, this along with my short commute was not allowing the Batt to recharge properly. He reset the code and test drove it , turning it off and on a few times. It is now on a trickle charger and im hoping im o.k. Keep your fingers crossed !I hope yours ends well too.
Old Oct 27, 2009 | 03:13 PM
Gordo's Avatar
Well that lasted a couple of days ! Thought it was a little too good 2 b true. Im headed out to buy a code scanner. May as well learn something along the way.
Gotta roll with the punches mate.
Old Oct 27, 2009 | 04:26 PM
H20boy's Avatar
sorry gordo, but a good scanner will pay for itself in the long run
Old Nov 3, 2009 | 11:16 AM
Gordo's Avatar
Back in business ! Trickel charged for a few days , seemed o.k. Engine light was still on for a few more. Finally no engine light. Looks like Batt or Alternator. I still ordered the code reader just in case. Thx for the good wishes!
Old Jul 27, 2011 | 08:02 PM
nine7xk8's Avatar
im having the same problem. im going to take it to a mechanic next week and see if its low transmission fluid. get the transmission fluid changed
JaguarLover101
48
Jun 12, 2023 10:28 AM
3lvis
Oct 1, 2015 01:56 PM
dmatthewman
Sep 30, 2015 10:10 AM
jjmiah217
Sep 28, 2015 09:09 AM
