Hello - Jaguar XK8 World :)
Old May 9, 2022 | 05:04 PM
robak's Avatar
Smile Hello - Jaguar XK8 World :)
Hello from Germany
I´d like to introduce myself. I´m 33 years old and live in Germany (Bavaria).
I´ve bough myself a XK8 from the US (4.2L convertible - built 2004) with some "special" problems (rust, electrical stuff, transmission problems etc.) Well I didnt know that it had so many issues.
On the way getting the car working again i found this forum and it helped me really much. I hope to get some further tipps and i apologize in advance for my bad english :/
Greetings from Germany
Rob
Old May 9, 2022 | 05:15 PM
robak's Avatar
Sorry for this Thread. I just found out that there is a special category here for the introduction.
Old May 9, 2022 | 08:09 PM
RJ237's Avatar
Welcome to the forum. Very few US cars have rust problems as the northern ones are not generally driven in winter. Please present your problems.
Old May 9, 2022 | 09:31 PM
Stamford's Avatar
Welcome. As you've seen there is a wealth of valuable information here. I don't know I would have bought my Jaguar if I had not known about this site. I read Forum posts for over a year before I decided to buy an XK8 - best (and most reliable) car I've ever owned or driven. By the way, your English is fine -- much better than my German.
John
Old May 10, 2022 | 01:14 AM
Pistnbroke's Avatar
Welcome ..we can sort you out but remember Photos are worth a thousand words.
Go Advanced
Manage attachments
download from computer SD card or whatever
Upload button and your done
Old May 10, 2022 | 07:17 AM
SamtheSham's Avatar
Rob,
Welcome to the best source of info for your car. Good luck with your work.
"Gros Got",
Sam
Old May 10, 2022 | 12:36 PM
robak's Avatar
The biggest problem is, that somehow very much water came in for a very long period of time.
The left side (driver and passenger behind the driver) is totaly damaged. I cant rly tell where it came from. If you want i can add some creepy pictures of the rust.
Also there is rust at the typical spots in the rear left and right (where the rear frame is attached) and behind the front carrier (sides).
Old May 10, 2022 | 12:37 PM
robak's Avatar
Thanks alot guys. that nice from you. Ill upload some pics later and give some detail I already got done.
Old May 10, 2022 | 02:06 PM
Pistnbroke's Avatar
Leaking rear window ..gets behind the frame then rusts a hole in the bottom edge and runs down into the area under the back seat and hence flows over into the rear . Then forward into the foot wells ...
Old May 11, 2022 | 03:57 AM
robak's Avatar
can you please show me a picture from the spot you think? not the side rear window?
is the rear window a typical spot? easy to fix?
Old May 11, 2022 | 04:10 AM
Pistnbroke's Avatar
Mine had a gallon of water under the RH back seat ...went over and under the carpet to rot out the drivers footwell. Also leaks into the boot and down into the sill area...
What I did ..
Small bead of silicone along the top edge of the window trim from front to rear ..it seems to pull away and rust behind any way.
The rear window surround is easy to remove prise up on the RHS about half way up and it arches up as its in two pieces L and R . Only problem is you may destroy the rubber seal so cut away whats crap and when its re fitted go around with silicone .Its held with clips not glue. The area around the glass acts as a water channel so it goes to the bottom and rots it out
You may find a hole /rust area bottom RH corner. I treated mine with marine epoxy ..the only thing that kills rust cus it takes 24 hrs to set and soaks into the rust.
Also check the rubber seal around the wire in the top RH corner of the boot flange ..its not where it fits the body but the little tube thing that comes up that perishes and lets the water in ..
Mine is dry now.
If its parked uphill the water goes into the boot ..if downhill into the sill../back seat area.
Send photos
Old May 11, 2022 | 01:13 PM
robak's Avatar
okay, i´ll check that as soon the floor pan is back in and i can mount the seat again Thank you
Old May 11, 2022 | 01:19 PM
robak's Avatar
passenger floor panel (behind driver)
driver floor panel
rear left subframe attachment
passenger floor panel (behind driver) - picture from below
driver floor panel - picture from below
spare part from wrecked XK8
inserted spare part (not finished)
Old May 11, 2022 | 05:00 PM
michaelh's Avatar
Hi robak,
You have some work to do, although I see you have already made a good start.
Member XKR-DAY has been doing some superb body repair work on his XKR. Have a read through these threads. They are long, but they will help guide you and there are LOTS of pictures:
https://www.jaguarforums.com/forum/x...3/#post2286035
https://www.jaguarforums.com/forum/x...2/#post2481381
Good luck!
Old May 11, 2022 | 07:23 PM
CA Jag's Avatar
Good luck with it. This forum is an incredible source of information on these cars. We all share an enthusiasm for these cars. I never would have been able to get my 2000 running w/o the knowledge and support in here.
Old May 12, 2022 | 12:37 AM
Pistnbroke's Avatar
Just noted this guy has a Convertible so my window comments dont apply but its been leaking somewhere and sitting for a long time
Old Mar 5, 2023 | 04:24 PM
robak's Avatar
hey guys. long time ago now.
Soon ill give you a update how the car looks now. Took so much time, money and sweat
Dennis07
Nov 27, 2019 12:53 PM
Safari
Sep 28, 2014 12:31 PM
Jag happy
Oct 23, 2013 03:10 PM
WhiteXKR
May 19, 2013 12:03 PM
