Locked Keys in Boot and Battery is disconnected..!!!
Old Sep 6, 2019 | 08:09 PM
XKR2000's Avatar
Exclamation Locked Keys in Boot and Battery is disconnected..!!!
HELP..!!!! I have locked the Keys in my trunk and I am at a loss as how to get the trunk open..????? Any ideas..? I have no SPARE...the battery is disconnected and I cannot access the trunk from the rear seat.
Any help appreciated....
Old Sep 6, 2019 | 08:23 PM
mhminnich's Avatar
Have the dealer cut a non-chip key?
Old Sep 6, 2019 | 08:31 PM
XKR2000's Avatar
I could...but is there is another way..??? Is there a method for opening the trunk without a key...maybe through holes behind the license plate..??? I found another thread speaking of this...but not for an XK..?
Old Sep 6, 2019 | 08:45 PM
avern1's Avatar
If you have access to the cabin. Open the bonnet and on the drivers side you will find a terminal that you can hook jumper cables or a battery to. It is a positive only and you can ground anywhere, then try to release the boot with the interior button. Be careful and watch for cables getting hot which would indicate battery cables in the boot are grounded.
Old Sep 6, 2019 | 08:58 PM
motorcarman's Avatar
USE YOUR OTHER KEY!!!!!!!!!!!
Please don't say you only have one key!
bob
Old Sep 6, 2019 | 09:17 PM
XKR2000's Avatar
Can you tell me where to find this terminal..? I don't see anything on the drivers side..? Please and thanks
Old Sep 6, 2019 | 10:58 PM
Johnken's Avatar
Open hood.
Stand on drivers side (USA)
See shock absorber (black plastic cap in center, 3 shock bolts each covered in black plastic) by your belt buckle. We will use this to find the 12volt terminal.
Dead reckoning:
Touch shock bolt closest to engine. Now move hand back toward you and left to next shock bolt.
Move hand left about 2 inches towards front of car.
In a few inches see black rectangular fuse box (black plastic rectangle cover)
Move hand over this box, move toward edge closest to engine.
Right rear Corner of that edge = see black flexible rubber cap. It covers the 12volt battery terminal.
Remove cap, silver bolt is battery.
Ok to connect 12v here. Will give you power to press trunk release button. Charger is OK. BUT: NEVER TRY TO START THE CAR FROM THIS TERMINAL. You'll blow the 50amp fuse. Remember Vern's note about hot cables (above).
John
Old Sep 6, 2019 | 11:35 PM
DavidYau's Avatar
Default Pic of Positive battery terminal in engine bay
A pic speaks a thousand words
Old Sep 7, 2019 | 12:14 AM
Johnken's Avatar
Much much easier!!!!! ;-) love it Dave
Old Sep 7, 2019 | 01:37 PM
XKR2000's Avatar
Thanks everyone...really appreciate it.
Old Sep 7, 2019 | 02:41 PM
funracer's Avatar
Did it work?
Old Sep 7, 2019 | 04:21 PM
XKR2000's Avatar
UPDATE:
Tried this method and it did not work...? Guess I'll have to contact a dealer and get a spare key made. I'm currently working on the car so no rush...it's not my daily driver.
I'm still open to any other ideas however...thanks all.
Old Sep 7, 2019 | 05:21 PM
bobhoff's Avatar
Did you use Battery Charger or Jumper Cables? I had the same issue. I tried Battery Charger and it didn't work. I tried jumping from my Truck and it worked. Doesn't seem like it would make a difference but it did.
Old Sep 7, 2019 | 05:29 PM
XKR2000's Avatar
I tried jumper cables...no luck..???? Not sure WHY it didn't work...but..???
Old Sep 7, 2019 | 05:47 PM
cjd777's Avatar
Besides making a good connection at the Positive terminal, you need a good ground, not the shock tower.
Good luck.
Old Sep 7, 2019 | 06:14 PM
XKR2000's Avatar
Good luck.
Well...YOU were correct sir..!!!! I tried again and moved the ground around until I found a good spot...and it worked fantastically....THANKS TO YOU ALL..!!!
Old Sep 7, 2019 | 09:08 PM
DavidYau's Avatar
Default I would still get another key
bob
Congrats on opening the trunk. Now get another key made. Lots of info in this Forum on sources to get a blank Tibbe cut relatively inexpensively.
I too only had one master key, so trimmed the tip of my green valet key to become a spare driver key ... and I’ve used it a few times to open the trunk when I stupidly closed the car door with battery disconnected and key inside.
Old Sep 8, 2019 | 05:09 AM
DavidYau's Avatar
Default Some info on keys
Check this out
https://www.triple-c.com/How_To_Read..._Key_Codes.cfm
Old Sep 23, 2019 | 11:44 AM
kilog's Avatar
Originally Posted by Johnken
Open hood.
Dead reckoning:
John
Hello,
On an S-Type R6 2001
I was able to inject 12V inside the car,
But unfortunately it did not work because of the alarm that is alware eanble.
So electrically I have light inside the car, can open the gas tank access hatch
but no way to release the boot with the interior button.
please help
I am blocked in the bush
Regards
Old Sep 24, 2019 | 08:24 AM
Johnken's Avatar
Looks like you were trying to type always enabled. Heres the problem, you've got an S type not an XK8. I am not sure of the difference with that model.
Maybe you'll get faster answers in the S type forum?
If you go there say these things:
Alarm type ( factory or aftermarket)
Whether you can turn alarm off with key in door (we can on xk8)
How it is that the alarm has power if the trunk open button doesn't
Oops, I just realized my key in door question is a dumb one - keys are in trunk! Laughs on me there...
How did alarm turn on if keys are in trunk?(might as well address it)
Hope this helps
John
slidefighter
Apr 29, 2018 07:14 PM
gagman66
Jan 19, 2017 07:46 PM
King Charles
Nov 22, 2015 07:16 PM
Chris Ryan
Oct 26, 2012 10:43 AM
haggis95
Jan 21, 2011 06:08 PM
