Ok, I give up, where's the photo located?
Old Jan 17, 2015 | 08:46 AM
marvin.d.miller's Avatar
Talking Ok, I give up, where's the photo located?
So, somewhere on this post there is a photo of an XK8 engine that has been removed and all of the timing chain tensioners are in plain view. I've searched for about 45 minutes to find the photo and I give up. I can't for the life of me find it. Can someone point me in the direction of the post with the photo? It's pretty much a straight on photo.
THANKS FORUM PEEPS!!!!
Old Jan 17, 2015 | 09:14 AM
There must be a gazillion pics of tensioners!
Try here https://www.jaguarforums.com/forum/x...ics-how-52653/
Old Jan 17, 2015 | 09:41 AM
Default Not the needed picture, but...
Not the needed picture, but thank you for the attempt. The picture I'm searching for is fairly recent, shows the engine removed from the car and the water pump and covers removed, exposing the timing chains/upper & lower tensioners. Full on photo of a stripped down engine front end, but with the chains/tensioners in place.
Old Jan 17, 2015 | 11:03 AM
palantir's Avatar
One on this one.
https://www.jaguarforums.com/forum/x...rtblock-90562/
Old Jan 17, 2015 | 11:27 AM
Default Close, but not quite
Thank you the link, but alas, it's not it. The one I'm searching for is angled in such a way that you can see the tops of all four chains. Same view, just angled differently.
Old Jan 17, 2015 | 11:53 AM
DevonDavid's Avatar
This one ......... ????
Old Jan 17, 2015 | 11:58 AM
Jandreu's Avatar
See post #17 here
https://www.jaguarforums.com/forum/x...tioning-17726/
Old Jan 17, 2015 | 12:35 PM
Originally Posted by Jandreu
I think that's the same pic that David posted, will there be a prize for whoever can find the right one?
Old Jan 17, 2015 | 01:11 PM
DevonDavid's Avatar
It would be my pleasure to share any prize with Jandreu.
Hint ................ http://www.bbr.com/products-326-1982...child-pauillac
Old Jan 17, 2015 | 01:53 PM
Forget the engine rebuild, pass the corkscrew.
Old Jan 17, 2015 | 02:36 PM
Jandreu's Avatar
Old Jan 17, 2015 | 03:52 PM
Is there an extra glass?
Old Jan 17, 2015 | 06:07 PM
SteveJacks's Avatar
You could try an advanced search, enter some key words such as tensioners or engine swap, or something else you think may have been in a post, then restrict the search results to the XK8/KXR forum, and finally sort the results by date - if you beleive it was a recent post as you say, it may narrow the threads enough to find it.
Old Jan 17, 2015 | 07:16 PM
Talking
Devon-david!!!! That's it!!!!! Thank you very much!!! Thou art truely a jaguar forum mah-stah!!!!
That picture is going to be blown up to 34x44, framed and on my garage wall!!!!
Old Jan 18, 2015 | 06:36 AM
Originally Posted by marvin.d.miller
.... That picture is going to be blown up to 34x44, framed and on my garage wall!
Which one?
He gave you two!
Old Jan 18, 2015 | 10:39 AM
DevonDavid's Avatar
Put both pictures up - it would cost pretty much the same to go out and buy either one ( £5k / $7500 US )
aholbro1
Dec 29, 2024 06:46 PM
Nigels420G
Mark V - X 420G
Sep 17, 2015 10:29 AM
Clamdigger
Sep 12, 2015 03:43 PM
KarimPA
Sep 12, 2015 08:15 AM
hen555
Sep 7, 2015 11:13 PM
