First time Jag owner
Old Jun 10, 2019 | 08:29 PM
Sieve's Avatar
Default First time Jag owner
Just bought a 2006 xj8 with car too low warning. Tested relay tonight. All ok. Have power at one side of f6 but other side dead fuse is blown. Will disconnect wiring from compressor when it's dry outside and try a new fuse. How often do the compressors just die. By the sounds of it here its more common for the seal to go bad. Any pointers would be helpfull. Anyways greetings from Canada
Old Jun 11, 2019 | 02:49 AM
Welcome to the Forums.
The X350 members will sort your questions.
Good luck
Old Jun 11, 2019 | 02:55 AM
Welcome to the forums Sieve,
Follow this link https://www.jaguarforums.com/forum/x...-x350-x358-28/ to the X350 forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues.
You can also visit the Canada Region forum by following this link https://www.jaguarforums.com/forum/canada-73/ to find other members in your region.
Enjoy the forums.
Old Jun 11, 2019 | 03:20 AM
Daf11e's Avatar
Welcome aboard Sieve.
Old Jun 11, 2019 | 05:17 AM
Welcome to Jaguar Forums Sieve,
Old Jun 11, 2019 | 06:28 AM
Old Jun 11, 2019 | 01:36 PM
Hello,
Old Jun 11, 2019 | 09:29 PM
jerry_hoback's Avatar
Welcome Sieve, We just bought an 04 xj8 today, also with an obvious height challenge. Hopefully its and easy fix for us both!
Old Jun 12, 2019 | 03:02 AM
Sieve's Avatar
Thanks Jerry I checked the R1 relay and the F6 fuse in the engine compartment. I found the fuse blown ??????? so thinking It must be a bad compressor I put the car up removed the wheel, removed the inner wheel liner, removed the front panel below the bumper, removed the compressor and bench tested it with a battery and 30 amp fuse. IT WORKED. I reinstalled the compressor partially, put the wheel back on , replaced the blown 40 amp fuse, started the car and it came up well see how long it stays up , curious to find out why the fuse was blown Oh well I have to put everything back properly now
Old Jun 12, 2019 | 06:12 AM
Thanks for the run- down on your procedure. Looking around the car yesterday I was struck by the plethora of "don't come in here" panels and wondered if all my time for a repair would be removing and replacing them.... could be worse I guess...
Old Jun 12, 2019 | 06:21 AM
o1xjr's Avatar
Welcome to the forums.
Old Jun 13, 2019 | 09:02 PM
Sieve's Avatar
Jerry. Is your compressor running ? Occasionally ?
jsavner
Jan 22, 2019 05:26 AM
Brian H Smith
Apr 29, 2017 04:55 AM
IndelXK8
Mar 27, 2016 08:33 PM
Greggg
Mar 31, 2010 08:34 AM
scubayachts
May 11, 2007 09:57 PM
