Help 04 4.2L P0750 Transmission fault code
Old Sep 2, 2016 | 01:55 AM
LoganR's Avatar
Default Help 04 4.2L P0750 Transmission fault code
Got a good OBDII software for my Bluetooth OBDLink scan tool today, It gave me the P0750 code stating 5th gear value/setting not right, I thought I saved the exact wording before I cleared the code, but I missed a step in saving, I only trip the fault when speeding up in 6th gear trying to past fast, if slow speed-up no issue,and if I use J-shifter 5 setting to pass quickly, I never have a issue, If I pull over right away and turn off engine after getting Fault light everything work normal when I start back up, can drive it hard to 6th gear, At 50,600 original miles now, replaced fluid at around 49,000 w/factory lifeguard 6 (pricey stuff). problem was occurring before I did that, purchased car at 46,000 drove 1,100 miles home from purchase site no problems. Any Ideas what is going on?
Old Sep 2, 2016 | 07:05 AM
Datsports's Avatar
You mean "shift solenoid 'A' malfunction" p0750
I think this link will help you understand -
P0750 Shift Solenoid 'A' Malfunction OBDII Engine Light Trouble Code | Engine-Codes.com
Old Sep 2, 2016 | 10:33 AM
LoganR's Avatar
Yes when I dig deeper into my software to explain code it says when you get this code, default action - mechanical limp home mode, possible causes - control valve failure pressure regulator solenoid 1 circuit malfunction.
I just have a issue with when problem occurs, if a part is bad its bad,, you generally have a consistence problem all the time, which has me wondering if something else is causing code to trip, when I click further for more info I get a photo with no explanation of what looks like 2 bolts over a linkage here it is -
I'm going to take a look on my car.
wish had better photo of where this photo is dropped safety shield didn't see it.
Old Sep 2, 2016 | 11:13 AM
Mikey's Avatar
What's 'original miles'? Are there some that are unoriginal?
That looks like part of the suspension, nothing to do with your transmission fault.
Old Sep 2, 2016 | 01:56 PM
JagV8's Avatar
Only true sometimes. Often untrue for parts with movement or oil - your case quite likely.
Old Sep 2, 2016 | 03:34 PM
LoganR's Avatar
You maybe right, I don't see that photo anywhere near transmission, had read a few msg to check linkage bolts in and earlier post on this issue, gonna send msg where those bolts are located. the mileage was to cover if engine or tranny had been replaced before,, at 12 years you gotta wonder, if that could be a cause.
Old Sep 2, 2016 | 05:06 PM
Datsports's Avatar
That picture is clearly not for an s type at all .
It shows a a front wheel drive set up ,
and the two bolts are sway bar mounts .
So forget that !
First thing you need to check is the trans fluid leval .
At the correct temp
I think you also need to un plug the matronics connector on the back of the trans and check to see if it's clean and installed properly .
With no oil present in the socket .
Failing that it will have a chafed wire inside the trans or the solenoid is sticking requiring a new one .
Old Sep 3, 2016 | 01:32 AM
LoganR's Avatar
So forget that !
At the correct temp
Yea thanks, after a few minutes under car we came to same conclusion, I just love paying for crap information, I'm thinking now problem is not a DIY, may take a look at matronics connector, kinda of wish problem would occur in different gear or trans would act up at other times, hard to see how solenoid can only be bad in one gear only under hard ace.
Old Sep 3, 2016 | 02:26 PM
abonano's Avatar
Each forward gear has a solenoid. It could be sticking intermittently or there could be other causes (already mentioned in the thread)
If your TCM harness checks out then you have to drop the pan, unbolt the TCM from valve body and visually inspect/test the solenoid.
Another viable solution could be as simple as a reflash of the TCM as your trans case may be wearing and might not have the latest programming in the TCM to account for wearing of the trans via fluid pressure values.
Hope the above helps...
Old Sep 7, 2016 | 09:56 AM
LoganR's Avatar
Me Too, Thanks for info I didn't know/understand, and showing me another path to look at, I had ran into a wall trying to troubleshoot this problem, could find very little info on it.
Old Sep 7, 2016 | 10:08 AM
LoganR's Avatar
Yea my Dad has been helping me thinks you have a good point, Its a frustrating issue I love black and white issues, these gray ones they suck
Old Sep 7, 2016 | 11:26 AM
JagV8's Avatar
Not sure it's good news but such faults often get worse and then you're into the "it's bad" situation. (If you can figure it and fix it sooner, do.)
vsol
Apr 15, 2016 07:11 AM
guppy710
Apr 2, 2016 02:12 PM
Dean Kitching
Mar 30, 2016 02:53 PM
JohnBurns
Oct 19, 2010 02:30 PM
aquill1
Nov 1, 2006 05:04 AM
