2002 3.0l auto trans - level plug location
Old Jul 31, 2011 | 10:57 AM
sgf's Avatar
sgf
Default 2002 3.0l auto trans - level plug location
Ok guys, I feel like the dumbest guy in the room. Searched all over the forum (and google) and under my car but I cannot locate the trans fluid level plug per the photos that have been posted. I found the tranny fill and drain plugs as well as the TC plug.
Any help would be appreciated. Apologies in advance if perhaps I am missing something obvious.
Old Jul 31, 2011 | 11:57 AM
motorcarman's Avatar
The fluid level plug and drain plug are one and the same, It just depends what part you unscrew.
Here is a TSB for trans leak and fluid level check.
bob gauff
Old Jul 31, 2011 | 12:57 PM
sgf's Avatar
sgf
Thanks, but I can't access the PDF because of a permission problem. I am logged in so I am not sure why?
Old Jul 31, 2011 | 01:31 PM
Gold_04_X-Type's Avatar
bob gauff
That's for an S-Type. Completely different setup.
Old Aug 1, 2011 | 07:24 AM
Sorry!!!
I thought I was in the S-Type section.
Similar setup with the level tube in the bottom.
Same gearbox as the VW jetta 09A (JATCO)
bob gauff
Old Aug 1, 2011 | 11:28 AM
sgf's Avatar
sgf
Is there a doc that describes how to do this?
I guess I am confused a little, I thought it was the same as the other photos that I have seen where there is a level plug.
Old Aug 1, 2011 | 12:03 PM
The fluid level is checked @ 35 degrees centigrade. Here is a Rover bulletin.
Freelander - Gearbox Fluid Level - Plug Location - Land Rover
The JATCO JF506E is used in the VW jetta, Rover freelander and Jaguar X-Type.
Level plug is the 5mm allen socket on the bottom of the gearbox.
Don't remove or loosen ANY OTHER BOLTS!!!!!!!!!!!!!!
I just did a quick google search for JF506E fluid level check and found lots of info.
bob gauff
Old Aug 1, 2011 | 02:44 PM
Check the FAQs, I posted a very clear picture of the location. It is right next to the gear selector cable on the bottom of the trans.
Old Aug 1, 2011 | 06:03 PM
sgf's Avatar
sgf
Thanks gold_04, I did look at your picture but I was not sure if that was from the 3.0l auto.
I found it, and please excuse my ignorance. I was expecting the plug to be on a vertical surface not on the bottom (I did not realize that your pic was taken directly in an upward direction.
Thank you everyone for your assistance.
Wolfy
May 28, 2024 08:06 AM
way2far
Aug 31, 2022 09:26 AM
Bcrary3
Sep 12, 2021 05:41 AM
cissdm
May 3, 2016 06:02 AM
Numwen
Sep 6, 2015 12:30 AM
