If i replace the radio amplifier Do i need to code it?? how?
Old May 13, 2021 | 05:20 AM
Jordan Garda's Avatar
Default If i replace the radio amplifier Do i need to code it?? how?
If i replace the radio amplifier Do i need to code it?? how would i do that?
Old May 13, 2021 | 12:23 PM
John Williams's Avatar
If its a simple like for like replacement, no coding required. If your adding an amp then the CCF file needs changing!
Old May 13, 2021 | 02:09 PM
hi this is a 2009 xf x250 s. And the radio looks like it... it has the same buttons. https://www.ebay.co.uk/itm/324282453...app-cvip-panel listing
Old May 14, 2021 | 07:47 AM
fivel's Avatar
The audio system is made up of a load of different parts and depends on what you have in your car. As long as the replacement is the same then it should just work. Point of note is that the power amp is optional and there are different installations with the power amp (8, 9 & 14 speakers), the IAM has to be configured to match.
Old May 14, 2021 | 12:17 PM
Car keeps randomly calling and changing sources this is why im replacing
I have plugged it in to diagnose machine and come up with amplifier faults. i am planning to replace amplifier but how is calling using that?
My mechanic doesn't think its the clock spring.
Is it more likely to be the information control module according to your diagram because there is no call function on the radio?
Old May 14, 2021 | 05:25 PM
fivel's Avatar
Ah, right. There's more to this. There is also the MOST network that links the sources such as the telephone:
The ICM (10 in this diagram) controls which source to use, but it does that based on commands from the steering wheel, the ICP or the touchscreen. So you could have a rogue ICM, but you could also have random inputs coming from another module that it is responding to. the MOST network has to work in a loop, so maybe if the amp is playing up its sending garbage on the MOST and that is confusing the ICP and making it do random things. What DTCs are you seeing?
Old May 15, 2021 | 07:56 AM
Sean W's Avatar
Follow Fivel's thoughts. It's the first place to start, but if you do go down the road of replacing your existing, you need the part number. "Looks the same" doesn't mean it is the same. As Fivel suggests, The MOST loop could be suspect and is usually easy to isolate. Codes are always the first place to look. MOST network errors will throw codes.
Old May 19, 2021 | 03:39 PM
Replacing the ice module and amplifier worked!!!! Thanks for all ur suggestions I guess it was scrambling errors
nickg112
Sep 17, 2017 06:06 AM
dsnyder586
Dec 12, 2014 09:41 PM
Terrymadtown
Jun 26, 2012 11:30 AM
brat_4742003
Oct 16, 2010 10:14 PM
GTRJohn
Jul 25, 2008 08:39 PM
