Instrument cluster and security module.
Old Jun 6, 2020 | 06:36 PM
John P's Avatar
Question Instrument cluster and security module.
Hello all,
I want to change the cluster in my 3.2 sport to the burr version and I need to fit a new security module.
I have both parts that have been removed from scrap cars, do I need to get them re programmed or will they be fine when fitted.
I guess the mileage is stored in the unit?
Any advice please?
Thanks.
John.
Old Jun 7, 2020 | 01:36 AM
Cafcpete's Avatar
The ‘wood’ is just a plastic facing that can be swapped over with not much effort.
Old Jun 7, 2020 | 04:50 PM
b1mcp's Avatar
I'm pretty sure you will need to re-programme for your remote fobs and for your keys (as you have an immobiliser).
The fobs are simple and the process is well documented in other threads. The programming of key transponders can only be done by Jaguar Diagnostics software (or may be a specialist locksmith?).
Old Jun 7, 2020 | 05:43 PM
John P's Avatar
Thanks for the answer`s.
It seems to be a lot of aggro, the car only cost £250, so as you can imagine I don`t want to spend vast amounts on things.
Changing the plastic may be a safer option.
John.
Old Jun 8, 2020 | 03:47 AM
SleekJag12's Avatar
No wonder the burl surround in the cluster never seems to match the real wood veneer used everywhere else. It's "simulated"! I'm tempted to go the other way and install the black sport surround panel with the silver trim rings set. But its not a priority for me.
Old Jun 8, 2020 | 12:01 PM
Cafcpete's Avatar
I went the other way, from black to wood!
Old Jun 8, 2020 | 02:24 PM
John P's Avatar
This is the way I want to go.
Did you need to re-set anything or just drop the new unit in?
John
Old Jun 8, 2020 | 04:18 PM
Cafcpete's Avatar
I just swapped the plastic not the whole cluster.
xjrwithproblems
Oct 20, 2021 08:09 PM
Anglo2000
Jun 25, 2018 04:07 PM
Phoenix_2k
XJ XJ12 ( X305 )
Jan 9, 2018 04:00 PM
linconlsv8
Sep 25, 2014 01:49 AM
Eclaudio1
Jun 18, 2014 08:22 PM
