Fuel Tanks, switch, transfer, etc...
Old Dec 30, 2011 | 06:29 PM
fgkell's Avatar
Default Fuel Tanks, switch, transfer, etc...
Anybody willing to teach me in plain English, how to use the dual fuel tank system on my '82 XJ6? I understand the obvious, there is a switch on my dash. I read of some talking about a transfer pump. Does it exist and how does it work? If it does exist, isn't a switch for right or left tank rather obsolete? Am i grossly misunderstanding?
Old Dec 30, 2011 | 06:48 PM
Doug's Avatar
This first couple paragraphs here might help----
Fuel Tank Switchover Checklist, Series III XJ6
---- if not, post back
Old Dec 31, 2011 | 09:30 AM
fgkell's Avatar
Very helpful, thank you. So, what's this about transfer pump (not from that article, but from another discussion)? Is there such a thing?
Old Dec 31, 2011 | 09:42 AM
Doug's Avatar
No transfer pump on your model.
Jaguar used dual tanks on many models in the 60s-70s-80s. Perhaps some of the older cars had a transfer pump...but it doesn't ring any bells with me.
Someone more familiar with the oldies might chime in on that.
Old Dec 31, 2011 | 09:57 AM
fgkell's Avatar
So far my switch seems to work well from left tank to right. My gauge doesn't work though. The guy I bought it from, told me it needed a sending unit. The fact that the gauge doesn't work on either tank leads me to believe it is not likely BOTH sending units.
Old Dec 31, 2011 | 10:14 AM
Doug's Avatar
Welllll....maybe not.
The sending units don't have the best reputation. Over the course of 30 years it isn't too far fetched that both have failed....possibly several years apart.
Easy test.....
Remove tailights to gain access to the sending unit wires
Unplug the light green wire
With the key "on" touch the light green wire to ground. The needle should move to "Full".
If the needle swings to full, the gauge/wiring/changeover switch is OK.... and the sending unit is faulty.
If the needle doesn't swing to "Full" then the problem is related to the gauge, wiring, or chageover switch
Old Dec 31, 2011 | 12:03 PM
Fraser Mitchell's Avatar
AFAIK Jaguars with twin tanks in the rear wings never used a transfer pump. Twin tanks were fitted on the 60s S-Type, the 420, and the XK saloons Series 1, 2 & 3. The Mark VII, VIII, and IX may have had twin tanks, but these are before my time. Cars with carburettors may have had one pump per tank, but no fuel return system as it's not necessary.
Old Dec 31, 2011 | 12:11 PM
fgkell's Avatar
Any real advantage to having the two tanks isolated and switchable? Why not let them equalize?
Old Dec 31, 2011 | 12:38 PM
Doug's Avatar
Some guys DO abandon all the changeover equipment and let the tanks equalize via a common connection---generally a "Y" fitting to replace the chanegover valve.
That's all fine and well if you always park on a absolutley level surface. Think about what happens when one tank is lower than the other. If the tanks are only half full or so, no problem. But if the tanks are nearly full...well...your gas caps better seal perfectly :-)
Old Dec 31, 2011 | 01:02 PM
fgkell's Avatar
good point
Old Jan 1, 2012 | 05:14 AM
fgkell's Avatar
ok, touched light green wire to ground and my gauge read full so I believe both my sending units are toast
Old Jan 1, 2012 | 05:43 AM
New ones here: -
Jaguar Wholesale Parts Dealer | Jaguar Auto Parts
Old Jan 1, 2012 | 09:03 AM
motorcarman's Avatar
I have diagnosed and replaced dozens of fuel tank sender related issues. The most common is not the sender but the plastic floats that fill with fuel and SINK to the bottom.
The plastic floats crack where the retaining ring of metal wire holds them.
I used to replace them with brass floats from some other model car but that was back in the 80s and 90s when I worked on alot of them. I can't remember where I got the replacements from.
The floats are NSS from Jaguar so you will have to replace the sender or find a suitable replacement for the float if it is full of fuel.
bob gauff
Old Jan 1, 2012 | 03:48 PM
Very useful post from Bob Gauf. I had forgotten about float leaks. Leaks were once also found with carburetor floats. SU had brass ones soldered together, and it was commonplace to resolder them where a leak was found. Later they went over to plastic which were supposed to be less prone to leaks, but not repairable, of course.
Old Jan 15, 2012 | 02:41 PM
amcdonal86's Avatar
Does replacing the fuel sender require dropping the tanks?
Old Jan 15, 2012 | 03:48 PM
fgkell's Avatar
nope...just requires removing the tail light. BTW, I removed the sending unit to clean my tank and found it was seized with rust. After freeing it up and cleaning a bit, IT WORKS!! HAHA
Doug's Avatar
Nope.
Just remove the tail light asemblies and you can reach right in and change the senders. "A walk in the park"
Old Jan 15, 2012 | 04:20 PM
This particular park is a No Smoking area. Do be careful when removing and replacing these things. Disconnect the battery first so there is no possibility of a stray spark.
silkcat
Jan 18, 2025 04:29 AM
dsnyder586
Dec 29, 2024 07:39 PM
Razor
Aug 28, 2019 08:34 PM
hen555
Sep 7, 2015 11:13 PM
deanh
Sep 6, 2015 08:20 PM
