Series I with AJ6 engine
Old Mar 8, 2022 | 03:33 PM
  #221
Wilfred88's Avatar
I have spend quite some time thinking about this. The reason I did use it was because 1: I simply had it, and it was good and leak free. 2: the camper will be around 2600-2800 kilo when fully packed. That is about 1000 kg more than the jaguar the engine came from. So it will have to pull more.
Better safe than sorry, is what I am thinking.
Old Mar 8, 2022 | 10:21 PM
  #222
Jagboi64's Avatar
As a point of reference, I have a Daimler DS420 limo with the 4.2 and it weighs about 2800kg. I've driven it hard over the grades in the Canadian Rockies, and the oil was fine. Mind you, the exhaust did get hot. I had fitted an exhaust temperature gauge and on the long grades where I put my foot to the floor and hold it there for 25 km the exhaust temp went to 1100°C. However, that's a high as the gauges goes.... Normal highway cruise temperatures are about 550-600 °C.
Old Mar 9, 2022 | 02:01 AM
  #223
Wilfred88's Avatar
NIce, I really like the 420! it's a heavy beast though! I thought they were usually around 2100-2200 kg? Special edition?
Anyways, Maybe you are right, and I am overdoing it. However, I don't see any drawbacks of using the additional oil cooler, so as I have already fitted it, I will probably just leave it.
It's interesting Jaguar did fit the external oil cooler, and as far as I can tell they only got rid of it in the MY 93 onwards, when the radiator size increased.
Old Mar 9, 2022 | 11:12 AM
  #224
Jagboi64's Avatar
Most of the DS420's were fairly bare bones cars and mine is fully optioned. When I put it on a scale it was slightly over 2800kg. Interestingly, 1000kg less than my fathers Ford F250.
It certainly does no harm to have the cooler, but if you need to make space for something else you could get rid of it with no ill effect.
Old Apr 26, 2022 | 02:43 AM
  #225
Wilfred88's Avatar
still going well here. Lot of work done, but not interesting to share. Connecting hoses, lines. making brackets etc.
but now all in in place. only wiring needs to be integrated. it does crank, doesn't start as there is no fuel in the tank yet. Hopefully I will have time to get some fuel tonight, and fire it up!
Old Apr 26, 2022 | 02:41 PM
  #226
Wilfred88's Avatar
it runs again
Old May 20, 2022 | 01:14 AM
  #227
Wilfred88's Avatar
just a quick update on my series1 with the aj6 engine.
it's such a joy to drive, and it amazes mee how trouble-free I have been able to run this as daily driver for past year and a few months now. It really exceeds anything I was expecting. The only issue is, that I tow a lot and it doesn't really look good with a trailer behind it...
Old May 20, 2022 | 08:27 AM
  #228
yachtmanbuttson's Avatar
But it's the "classiest" tow vehicle going!!
Old May 31, 2022 | 05:33 AM
  #229
Wilfred88's Avatar
Meanwhile, more good times with the series 1
Old Jun 21, 2022 | 02:48 AM
  #230
Wilfred88's Avatar
It's alive and drove under it's own (jaguar) power!!!!
all seems well, only the idle is high. 1200 at idle (roughly) and it drops when I put it in gear, but not as far as it should, when in gear. anyway, pictures first:
new logo on the grill :-)
Old Jun 21, 2022 | 09:04 AM
  #231
HA! That's Great, Wilfred!
I especially like the Growler added to the grill!
Old Jun 30, 2022 | 03:48 AM
  #232
Wilfred88's Avatar
So, the high Idle remains an issue but I already ruled out a couple of things. no vacuum leaks, tps idel signal was 0.69 so I reset this to 0.55. replaced thermostat and coolant sensor. So now I will adjust the IACV, and should be good. other than that it runs great!
yesterday I took it for a spin again, and for the first time went faster than 30 kph. Up to 90 I think. It was warm, so also a good day to test cooling, but all seems fine. There were 2 issues.
1. the rear axle is not the right one. It's a 4.88 which makes it rev too much. It's quick of the line, but top speed is poor, or at high revs. I will add a tach, to get some numbers.
2. The oil pressure light came on... And you may guess why:
yep, the line blew from the oil cooler connection. Why? I simply forgot to tighten the hose clamp.... As soon as I saw it, I was like 'o yeah, that was one of the things I stille needed to check and tighten....'
so the trip home looked like this:
Yes, I towed it.... I know I shouldn't with an automatic, but is was only 1 mile from home.
Old Jul 19, 2022 | 02:38 AM
  #233
Wilfred88's Avatar
so, the authorities approved my conversion, and it's now official. 4.0 liter inline 6 petrol on paper.
Old Dec 13, 2022 | 05:15 AM
  #234
Wilfred88's Avatar
So, the series 1 with 4.0 liter aj6 engine has been our daily driver for nearly 2 years now. Time to look back.
First thing: we have 3 kids, and it's not really a big car. getting all the seat belts on is not the easiest job, but it works.
In the past 2 years, it never gave any reason to question it's reliability. I have made some minor paint work repairs, as there were som scratches. other than that, just maintenance.
and So much fun to drive! the 4 liter straight six is absolutely brilliant! so smooth, so much torque. You have to drive it hard every once in a while. It's just begging for it!
Old Jan 2, 2023 | 03:42 AM
  #235
Wilfred88's Avatar
so, busy christmas holidays with lots of family/friends visits.
and that means adding up the kilometers/miles. We did some 500 km last week I think, (310 miles or so). Such a joy to cruise in the jag with the familiy.
and of course some pictures:
Old Jan 2, 2023 | 05:27 AM
  #236
mickvic's Avatar
keep up the good work, I must learn how to weld
Old Nov 27, 2023 | 10:20 AM
  #237
kansanbrit's Avatar
Interesting thread. Well done Wilfred. Just about to do the same to mine......
Old Sep 1, 2025 | 01:43 PM
  #238
Wilfred88's Avatar
well, it's been a while. But I am still driving my xj6 series 1 with aj6 engine as daily driver. All year round. It's holding up brilliantly. Sometimes I do some touch up on the paint and fight back the rust, and that keeps it in good shape. allthough the front is still too high, after installing the lighter aj6 engine... even after all these years, I haven't found the timt to lower it.
even drove a wedding last month.
And also, still travelling through europe in my VW LT camper, with 4.0 liter aj6 engine. What's more, I am currently making another vw lt with aj6 engine!
the leftover from the donor vehicle have been brouth to the scrapyard last week...
Old Sep 2, 2025 | 04:56 PM
  #239
kansanbrit's Avatar
You are the AJ6 man !!
Old Sep 3, 2025 | 03:30 PM
  #240
slofut's Avatar
Truly amazing Wilfred!
watto700
Feb 29, 2020 07:23 PM
Jahmiata
Aug 20, 2018 11:38 PM
MarylaLuna
XJ40 ( XJ81 )
Apr 28, 2014 10:31 PM
Walter1982
XJ40 ( XJ81 )
Mar 12, 2010 12:49 PM
Walter1982
Mar 3, 2010 07:46 PM
