Variable Valve Timing question
Old Jun 8, 2022 | 02:48 PM
panthera999's Avatar
Default Variable Valve Timing question
My BMW's also use VVT, similar to what's on the jag engines, with similar solenoids.
On that car, they have a pair of very small oil filter units on the side of the engine, in place in the oil passages that feed the VVT, to prevent contaminants from fouling the VVT solenoids.These can be removed and cleaned when needed.
I'm going to pull my XK150 4.2 N/A VVT's and clean them but can't find any indication in the manuals for a similar small filter.
Anyone know if there is one separate from each VVT, or is on the oil filtering part of the VVT solenoid itself? Or simply ignored in the design? [question answered below --panthera]
Thanks!
Panthera
Old Jun 9, 2022 | 02:42 AM
I'm sure you are correct about the lack of additional filtering specifically for the VVT's and it was this design flaw that made JLR so pedantic about oil specification. Remember the early days of the dedicated grade of Castrol with a chemical tracer and warnings that warranty claims would be rejected if the 'wrong' oil was found in the engine.
It's avoidance of VVT issues that encourages me to make more frequent oil and filter changes than recommended rather than concerns about bore or bearing wear.
Old Jun 9, 2022 | 08:31 AM
guy's Avatar
guy
@GGG , reassuring to know I’m not the only one.
Many speak of “extended drain intervals” and “sealed for life”. I’m not subscribing to that.
Old Jun 9, 2022 | 09:04 AM
Good points, thanks Graham.
EDIT and CORRECTION: I reviewed the parts blowup and found that there is a filter for this unit. It's part of the Module Carrier, is PN AJ18264, and is < $10. Of course, since it's in the module carrier, the valve cover will have to come off to install it.
I was examining some engine data the other day and saw that I was getting very occasional misfires on one side. Since I was getting misfires on one side, this seems a commonality.
Note there were no codes. I was just digging into diagnostic data and saw the random misfires.
Caused me to want to dig into the VVT on my XK150, to see if I could easily clean it. First Learnings (see pic):
  • VVT on my engine requires valve covers be removed. On other cars, the VVTs can be removed from the engine with a single bolt.
  • I looked at online replacement to see how they were built. There is a replaceable screen on the internal module carrier, under the valve cover.
  • The two items above still lead me to agree with Graham that more frequent oil changes are better, since keeping the VVT clean is important to valve timing.
  • Guidance: If you're pulling the valve cover, to clean the VVT solenoid, replace the filter.
Fix? Change oil regularly to avoid varnish coating (and other crud) on the VVT's. I usually change mine annually, since I only put on 3-4Kmi per year. Maybe (open to debate) use something like Liquimoly engine flush when changing oil even if oil has been changed regularly in the past. If really necessary, grit my teeth and open the valve cover to clean the VVT's if I suspect varnish coating or get VVT codes.
Second learnings:
  • My VVT connectors were covered in oil. This is due to typical shrinkage on the VVT-to-Valvecover gaskets.
  • I opened the connectors and flushed them with MAF cleaner (other contact cleaners would work as well), reconnected them.
  • See pic. The left side connector has the open end of the plug facing forward. This forced seeping oil into the plug from air movement. The other side was cleaner, because the plug faces backwards, but still had oil in it.
Fix? Replace the VVT gaskets to prevent further seepage. Easy fix, gasket available for $5 each, takes 5 min each. See Below. Note this is N/A 4.2 engine. Did not examine SC or 5.0 engine.
Poor VVT management can cause misfires, according to the 4.2 engine manual. My engine was a bit rough on idle, and it seems to smooth out a bit after cleaning the oil out of the connectors.
ALSO: you can test your VVT's in place:
  • Remove connector. Use an ohmmeter to test resistance. Should be somewhere around 8 ohms.
  • A couple of leads and a nine-volt battery can be used to trigger the VVT. You should hear a click when the battery leads are connected to the wires.
  • That said, these are pretty simple, solid units -- they likely will not electrically fail. More likely is performance degradation from gum and varnish buildup in the unit. Or in my case, with oil flooding the connectors.
Hope this helps. Why Jag, unlike most other engine builders, chose to lock VVT solenoid and filter access beneath the valve covers, is a mystery.
Old Jun 16, 2025 | 10:29 AM
Much later, after I was questioned on existence of VVT oil screen on the 4.2 A:
  1. Cleaning the VVT on the 4.2 NA requires removing the valve cover.
  2. The solenoid bolt is removed, and the VVT solenoid can be removed for cleaning or replacement.
  3. The solenoid carrier is then available for cleaning if needed.
  4. There appears to be no Jag PN for a screen in the VVT solenoid carrier, at least any longer, so AFAICT, the number above is no longer valid.
  5. The carrier itself may not be available new from the dealer.
  6. Can't see if there is a screen filter for the unit (as there are on the BMW's for instance), in any of the pictures.
  7. If there is one, can be cleaned when cover is off.
  8. probably better searched by Ford PN since it's stamped on the carrier.
See below upload for PN's.
Panthera
Old Jun 16, 2025 | 10:45 AM
sicarumba's Avatar
That's really helpful information, thank you Panthera. Do you (or anyone) happen to know where the screen would be in the module carrier? Like, is it easily seen or does the carrier have to come off? Trying to weigh up whether or not to go through the pain of taking the valve cover off to try and clean the screen and VVT solenoid.
Old Jun 17, 2025 | 11:22 AM
ChiefyO's Avatar
Did you find a cure for your random misfires that were happening on one bank only ?
Old Jul 1, 2025 | 10:58 AM
ChiefyO's Avatar
[QUOTE=panthera999;2533218]Good points, thanks Graham.
Old Jul 2, 2025 | 03:05 PM
CA Jag's Avatar
When I bought my 07 XKR (30k miles) engine would sometimes make a quiet but noticeable “clatter” noise w cold start. Lasted maybe 10 seconds. Not a major engine problem. Car always smooth. Previous owner drove it 11k in 10 years. Oil changes every 2 years. I’ve owned it for 3 years. Driven weekly. No more “clatter”. Just did a full synthetic oil change. Absolutely smooth start. Was it a possible VVT problem because of biannual oil changes, not much driving?
hooperdoski
Feb 16, 2023 01:15 PM
Potvinguy
Apr 9, 2020 03:33 PM
Blake04VDP
23
Apr 12, 2016 08:59 PM
Gameblaster1
Mar 7, 2014 11:17 AM
alckc
Sep 10, 2010 04:46 AM
